808DA6 Posted September 1, 2007 Report Share Posted September 1, 2007 Need some help. DOes anyone have the Nissan p/n for the L18 head bolts? Are they interchangable w/ the L20 and L16? I've been searching ARP kits and they only have and stud kit for the L20B. Makes me think the 4cyl L's share the same bolts/studs. Thanks, Brian Quote Link to comment
banzai510(hainz) Posted September 7, 2007 Report Share Posted September 7, 2007 the 280zx turbo bolt is the upgrade but the OAL(height is the same as a L16/18. ARP does list 2 part#s 4206 L24-28 4201 for the L20. Maybe cause they are studs?????? Quote Link to comment
]2eDeYe Posted September 7, 2007 Report Share Posted September 7, 2007 The block is what changes height between the L16/18 and the L20, correct? So the head bolts would be the same. The 2 different part numbers are probably due to the quantity and not the size, as the 6 cyl uses more bolts. I got my zx head bolts here. http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=P7600-KIT Cheapest I could find, even when I tried to get less bolts for the L20 The ARP sets are studs though, which will having more clamping force. Quote Link to comment
'70dime Posted September 3, 2008 Report Share Posted September 3, 2008 what is the recomended torque settings for a cam'd L20 with oversized dished 280 pistons? Quote Link to comment
Phlebmaster Posted September 3, 2008 Report Share Posted September 3, 2008 Look here: http://www.olddatsuns.com :D Quote Link to comment
