zed1 Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) Over a year ago, I purchased some NOS Datsun/Nissan parts from a defunct dealership. The list has the Nissan part number in the XXXXX-XXXXX format, current retail value, model application (if currently determinable) and quantity. The parts relate to many of the 1960-1990 Nissan vehicles including; 1600 and 2000 Roadsters, 510, Access, Maxima, Stanza, Sentra, B210, 210 200SX, 240SX, 610, 720, 810, Frontier, Pulsar, Quest, Van and others. There are few Z car parts. The prices listed are the current retail value that I researched from several Nissan price sources. Make me an offer on any parts you want. Use ups.com to estimate the shipping charges from 75075. Thanks, Keith The info below was copied from an excel worksheet. (Sorry for the formatting.) OEM Part Number Description Retail Price Chassis Model 64101-B9502 Hoodledge L $261.51 H5010-7Z000 Rear Lower Valance $164.56 D21 Pickup 80700-14800 Regulator @ $15.26 720 Truck, 1300, 1400, 1600, 610 Sedan 56210-W6626 11925-77A10 Pulley Assy,idl $41.31 240SX, Pulsar, Sentra 24381-96E05 Bracket,fusible $7.44 15239-07N00 Oil Filter Gskt $2.18 24382-96E06 Cover,fusible L $4.12 80317-01P00 Plate,bck Dr Wn $10.33 Z31 300ZX 80319-01P00 Plate,bck Dr Wn $10.33 Z31 300ZX 01651-00471 Screw Grommet $2.03 25360-10V00 Switch Assy,door@ right $15.86 maxima, sentra, nx, stanza, 240sx, pathfider 999M1-B0000 Armrest Grey GS $66.00 B13 Sentra 74954-P7100 Insulator S130 280ZX 27677-M6600 999JM-N3000 N12 NX Blue-LH $79.17 B13 Pulsar NX 62665-13600 Overrider,front $27.21 87405-P7102 Cover,device Rh $3.69 S130 280ZX 28570-42E60 Control Assy,pa $363.92 U11 Maxima 14875-W0405 Connector,vacuu $7.27 28504-85E00 J30 Maxima 14055-U6000 Hose,water $3.47 610 Sedan, Pickup L4 28595-05F10 Buzzer,warn Ign $37.62 27671-B8061 Cable,control $3.74 55247-U1402 Clip @ $8.88 55247-U1402 Clip @ $8.88 14957-33M11 Brkt,vac Switch $3.22 Sentra 16033-H7206 Jet Main 145 $7.99 14055-U6000 Hose,water $3.47 80340-61608 23465-N3300 Set Stopper Pinion - starter motor $4.39 S30 280Z 08330-61612 Screw $0.14 16054-U6700 Jet Slow 48 $7.86 610 Sedan, 710 Wagon 11329-C4200 24075-11C10 999JM-N3000 NX Blue-RH stripe kit $79.17 N12 Pulsar NX 27682-H8820 Hose Flex Low $97.96 B310 210 99990-00915 Mac Wpl MLDG $64.43 810 810 999MW-84001 Light Bar Retrofit Kit D21 Pickup 93313-94G30 Side Panel left $463.36 D21 Pickup, std cab, long bed 11240-28000 Center front member 520/1 520, 521 Pickup 54611-32500 99990-10036 Zx Bur.gd.bur $76.03 S130 280ZX 96500-23100 Ash Tray , $12.18 B110 1200 25210-14800 Switch,dimmer $12.51 520/1 520, 521 Pickup G5930-89902 INSULATION PAD S30 240Z 23233-65561 76889-W6600 Ornament,d $14.67 A10 510 76962-U0100 Clip Retaining $1.60 B11 Sentra 87603-54A01 Stopper Assy,he $3.98 83248-U8100 Stopper,window $3.22 76958-01F00 Clip $2.25 S12 200SX 80222-34A05 Finsh,door Cnrh $9.11 B11 Sentra 87830-29R01 Escutcheon,shou $6.32 M10 Stanza Wagon 80673-21002 82297-Y1900 Bolt,guide Rail $2.23 87418-03P03 Knob Reclining $2.79 Z31 300ZX 93489-80W06 Plug Blind Blue $0.93 Pickup 79852-H6900 B210 B210 82550-17C00 Actuator,slide $224.22 GC22 Van 91714-15F00 Esctcheon,hinge $7.85 S12 200SX 80604-04E00 Handle Fr Dr Rh@ $58.79 U11 Maxima 87406-N8203 Knob Rec.dev Rd $3.20 S110 200SX 84958-11A02 Cover Lamp L $8.17 B11 Sentra 87405-P7901 Cvr Device In R $3.90 S130 280ZX 90464-11A00 Washer B11 Sentra 96409-N7801 Holder,sunvisor $2.82 87457-W1002 Cover 84945-21A02 Cvr Tail Lmp Lh $6.90 B11 Sentra 87406-N8205 Knob Reclining @ $3.48 S110 200SX 87602-50A02 Service File S $4.17 B11 Sentra 90575-21A00 Shim Adjust $1.94 B11 Sentra 87455-K0100 Cover Device Lh $7.32 84952-11A02 Cvr Shock Abs R $5.64 B11 Sentra 85036-N8511 Cvr Bmpr Rear $2.73 S110 200SX 92560-70A00 Grommet,rubber $4.08 B11 Sentra 16701-37504 Gasket Pump $1.22 22136-18005 Breaker Contact@ $23.58 22136-18005 Breaker Contact@ $23.58 41100-B5026 Kit Whl Cyl @ $9.52 620 620 Truck 44100-71225 Kit Whl Cyl @ $8.88 44100-71225 Kit Whl Cyl @ $8.88 23120-04P10 Bearing,ball - alternator $11.41 Z31 300ZX 22157-03A00 Rotor Head $7.70 B11 Sentra 16196-U6000 Valve,antidiesl $39.75 L18-20 87830-29R01 Escutcheon,shou $6.32 M10 Stanza Wagon 16079-23011 Gasket,cover $1.20 17089-G3900 Screw $0.90 08124-6951A Bolt Hex $5.31 18016-89926 Pad,accel Pedal $4.98 01456-00351 Screw $0.77 22472-17C09 Clamp $6.24 GC22 Van 01456-00041 Screw $0.54 00511-0020P Ring,o $1.01 08121-06028 Bolt Hex $1.76 21647-W2700 Clip Tube $13.68 00911-04710 Nut $0.92 18225-W8900 C2852-P9500 Sprngdetnt Pkg2 (only 1) $2.66 S130 280ZX 22102-A5500 Ignition Conden $4.71 S30 240Z 22102-U6003 Condenser @ $4.53 C2849-P9500 Pin Roll Pkg 10 (only 8) $2.31 C2817-P9500 Roller,cam $2.97 S130 280ZX 31940-80X25 Solenoid Repair $96.05 A32 Maxima 73630-15E00 W.strip,s.roof $135.34 U11 Maxima 87953-V5805 Cover,seat $13.21 93823-B9800 Board,splash Lh $11.97 620 620 Truck 62314-36A00 Fin,headlamp Rh $59.61 B11 Sentra 76922-40U10 Welt,body Side+ $61.95 A32 Maxima 25050-H7203 Assy,wire @ speedo cable $41.06 B210 B210 84932-H1800 Cover Lamp B110 B210, 1200 68752-80M00 Ventilator Assy $27.78 N12 Pulsar 21501-19W00 Hose,rad Upper $14.33 D21 720 Truck 2.0 & 2.4 engines 33169-C6900 Sping Shift Frk $2.13 43236-18000 GREASE CATCHER $3.01 13085-40F10 Timing Chain Gu $12.54 Stanza, Access, 240SX, Pickup KA24E 21750-17C20 Clamp,hose $1.24 GC22 Van 86475-N3700 Cover Device R 2+2 $10.74 S130 280ZX 2+2 13091-40F15 Chain Guide $53.84 Stanza, Access, 240SX, Pickup KA24E 32825-E4600 Spring,check reverse $0.78 S30 240Z, 4 speed 32845-18800 Ring,o, control arm $1.35 S30 240Z, 4 speed 73990-07A00 Cover S.window $1.59 B11 Sentra 90805-E4100 Striker assy, hatch $6.90 S30 240Z 32813-24901 Bracket,rod $11.79 32703-73701 Pinion,speedo $15.01 32851-14600 Spring,control $3.27 L16 transmission 85059-D1600 Box,rlh Marker $5.01 T11 Stanza 63874-50Y10 Moulding,front $20.46 B13 Sentra 39614-A9000 Bolt,side Flang $6.62 54308-A0825 Kit,seal Strut $26.85 96943-W1003 Finsh Consl Lid $4.48 65158-01W01 Bumper Hood $2.34 D20 720 Truck 84932-H1800 Cover lamp B110 B210, 1200 54308-A0826 Kit,seal 80870-H9121 Reinforce Assy $17.38 B310 210 54308-A0826 Kit,seal 62654-04A00 Plate Baf Core $2.91 B11 Sentra 68640-W5801 Striker Lock G. $6.21 A10 510 30610-08726 Kit. B Repair C/MCYL A10 510 54308-A0826 Kit,seal 29352-P7100 Escutcheon,baln antenna $1.89 S130 280ZX 99990-10036 Zx Bur.gd.bur $76.03 S130 280ZX 38154-60401 40179-A8600 Nut, slotted hex , knuckle arm $3.81 240 76868-U0100 Bumper,door Re $1.29 76999-V5100 Clip,garnish $1.31 31932-X0103 Rod,diaphram, a/t $0.90 S30 240Z 41124-16505 Service File P $3.75 13028-8B000 Chain,timing $46.65 Stanza, Access, 240SX, Pickup KA24E 13070-40F06 Chain Tensn $65.70 Stanza, Access, 240SX, Pickup KA24E 13075-40F10 Bolt Tensioner $1.87 Stanza, Access, 240SX, Pickup KA24E 54613-M1000 N10 310 63143-N5800 Mldg,frt,finish $11.99 S10 200SX 31932-X0104 Rod,diaphram, a/t $0.90 S30 240Z 41124-16505 Service File P $3.75 32853-03200 Boot,lever $2.43 32831-C6900 Spring Lock $0.96 68790-W7500 Grille Vent $14.09 A10 510 28177-57G00 Grille,speaker+ $8.28 D20 720 Truck 77700-89902 Plug @ $1.62 32268-H7302 Ring,snap $1.78 B310 210 67915-01P03 Cover,blue $6.86 Z31 300ZX 38321-H3000 Cover brea 86606-N9617 Button Blue $4.44 32268-H7300 Ring,snap $1.78 B210 B210 73631-W1011 Shim $1.41 A10 510 32354-H9000 Nut $9.77 B110 B210, 1200, 60 series transmission 55553-E4100 Washer, rear suspension, traverse link $1.35 S30 240Z 32268-H7300 Ring,snap $1.78 B210 B210 41005-16505 Nut,hex $0.72 32221-E9500 Spacer,counter $2.82 S30 240Z 73557-P8100 Washer Shade $2.27 S130 280ZX 96301-04A10 Mirror Outsid R $110.14 B11 Sentra 96301-14A11 Mirror Outsid R $83.37 VAR 280ZX , Sentra, 200SX, 240SX, Maxima, Stanza 68920-D1401 Cover,inst Drve $36.25 T11 Stanza 76960-N4600 Garnish,black $13.16 S30 280Z 54611-????? 80870-2B509 Service File M $61.26 B11 Sentra 72762-13E00 Mldg W.s Lwr @ $150.75 U11 Maxima 76451-H9120 Sill,inner Lh $79.35 B310 210 79121-P9900 Rr Panel Lwr @ $122.78 S130 280ZX 40315-37A00 Cap Road Wheel @ $43.86 B11 Sentra & Stanza 66911-N3000 Trim Dash R. kick panel $8.89 S30 240Z 92111-40F65 A/C condensor S12 200SX 85020-N8520 Bumper Ctr Rear $263.46 S110 200SX 79122-N8500 Rear Panel Lwr $104.24 S110 200SX 21475-H2300 Shroud,radiator upper $22.46 B110 B210, 1200 28830-13E22 U11 Maxima 63810-88400 Fender over 63811-88400 Fender over 80214-0B000 Sash Assy,front $9.92 V40 Quest 80821-H5002 Moulding Lh @ $40.17 B210 B210 93829-8B400 Fender,over+ Re wheel flare $36.43 D21U Pickup 31070-P7100 S130 280ZX 17509-60500 17509-60?00 99990-00900 moulding lip, coupe, 2+2 S130 280ZX 99990-00681 moulding lip rt $135.69 99990-00681 moulding lip rt $135.69 99990-00699 moulding lip 72810-H1106 65510-B9500 ROD-HOOD-SUPPRT $7.48 620 620 Truck 65432-N8201 bar S110 200SX 65433-N8201 bar S110 200SX 65433-N8201 bar S110 200SX 65432-N8201 bar S110 200SX 40315-S3550 trim ring kit 14" D20 720 Truck 28138-60A00 Speaker unit RH grill 71.76 B11 28174-60A00 Speaker unit RH bezel 29.67 B11 99993-00316 Radio face plate B110 1200 78822-U2000 "Datsun 1800" emblem 1800 68930-01G00 Cover Instrument LH $17.95 99993-00401 Radio Console B210 B210 93885-27W25 Accent Stripe -short body RH blue D20 720 Truck Edited May 27, 2009 by zed1 Link to comment
sssr20det510 Posted May 27, 2009 Report Share Posted May 27, 2009 post up all the numbers i want 510 stuff Link to comment
NSRz32 Posted May 27, 2009 Report Share Posted May 27, 2009 Any idea on what the parts are/fit or do you just have the numbers? In your post it mentions list price and application but you didn't post them. Thanks! Link to comment
athoose Posted May 27, 2009 Report Share Posted May 27, 2009 85020-N8520 Bumper Ctr Rear $263.46 S110 200SX 79122-N8500 Rear Panel Lwr $104.24 S110 200SX 65432-N8201 bar S110 200SX 65433-N8201 bar S110 200SX 65433-N8201 bar S110 200SX 65432-N8201 bar S110 200SX Any physical descriptions or photos of these. Thanks Link to comment
zed1 Posted May 27, 2009 Author Report Share Posted May 27, 2009 The descriptions are from the Nissan parts catalogue. I have not taken pictures of the 200+ parts. 95+% of them are in their original boxes or plastic bags. Keith Link to comment
zed1 Posted May 31, 2009 Author Report Share Posted May 31, 2009 (edited) zerow, 78822-U2200.jpg image is in my album http://forum.ratsun.net/album.php?albumid=299&pictureid=1369 Edited June 1, 2009 by zed1 Link to comment
zerow Posted June 1, 2009 Report Share Posted June 1, 2009 zerow, 78822-U2200.jpg is in my album http://forum.ratsun.net/album.php?albumid=298 Hi zed1: Link is broken - please check link. Thank You! Link to comment
zerow Posted June 10, 2009 Report Share Posted June 10, 2009 Zed1, The emblems arrived in fantastic shape. Great part, great price, and fast shipping - THANK YOU! Looking forward to putting them on the car. :D Link to comment
green510 Posted September 5, 2009 Report Share Posted September 5, 2009 Thank you for the trim rings set. It is great. Brand new as you said. Thanks! Link to comment
zed1 Posted September 28, 2009 Author Report Share Posted September 28, 2009 All parts are sold. Thanks to everyone who purchased. Keith Link to comment
