NOS Datsun/Nissan parts
Over a year ago, I purchased some NOS Datsun/Nissan parts from a defunct dealership.
The list has the Nissan part number in the XXXXX-XXXXX format, current retail value, model application (if currently determinable) and quantity.
The parts relate to many of the 1960-1990 Nissan vehicles including; 1600 and 2000 Roadsters, 510, Access, Maxima, Stanza, Sentra, B210, 210 200SX, 240SX, 610, 720, 810, Frontier, Pulsar, Quest, Van and others. There are few Z car parts.
The prices listed are the current retail value that I researched from several Nissan price sources. Make me an offer on any parts you want. Use ups.com to estimate the shipping charges from 75075.
Thanks,
Keith
The info below was copied from an excel worksheet. (Sorry for the formatting.)
OEM Part Number Description Retail Price Chassis Model
64101-B9502 Hoodledge L $261.51
H5010-7Z000 Rear Lower Valance $164.56 D21 Pickup
80700-14800 Regulator @ $15.26 720 Truck, 1300, 1400, 1600, 610 Sedan
56210-W6626
11925-77A10 Pulley Assy,idl $41.31 240SX, Pulsar, Sentra
24381-96E05 Bracket,fusible $7.44
15239-07N00 Oil Filter Gskt $2.18
24382-96E06 Cover,fusible L $4.12
80317-01P00 Plate,bck Dr Wn $10.33 Z31 300ZX
80319-01P00 Plate,bck Dr Wn $10.33 Z31 300ZX
01651-00471 Screw Grommet $2.03
25360-10V00 Switch Assy,door@ right $15.86 maxima, sentra, nx, stanza, 240sx, pathfider
999M1-B0000 Armrest Grey GS $66.00 B13 Sentra
74954-P7100 Insulator S130 280ZX
27677-M6600
999JM-N3000 N12 NX Blue-LH $79.17 B13 Pulsar NX
62665-13600 Overrider,front $27.21
87405-P7102 Cover,device Rh $3.69 S130 280ZX
28570-42E60 Control Assy,pa $363.92 U11 Maxima
14875-W0405 Connector,vacuu $7.27
28504-85E00 J30 Maxima
14055-U6000 Hose,water $3.47 610 Sedan, Pickup L4
28595-05F10 Buzzer,warn Ign $37.62
27671-B8061 Cable,control $3.74
55247-U1402 Clip @ $8.88
14957-33M11 Brkt,vac Switch $3.22 Sentra
16033-H7206 Jet Main 145 $7.99
80340-61608
23465-N3300 Set Stopper Pinion - starter motor $4.39 S30 280Z
08330-61612 Screw $0.14
16054-U6700 Jet Slow 48 $7.86 610 Sedan, 710 Wagon
11329-C4200
24075-11C10
999JM-N3000 NX Blue-RH stripe kit $79.17 N12 Pulsar NX
27682-H8820 Hose Flex Low $97.96 B310 210
99990-00915 Mac Wpl MLDG $64.43 810 810
999MW-84001 Light Bar Retrofit Kit D21 Pickup
93313-94G30 Side Panel left $463.36 D21 Pickup, std cab, long bed
11240-28000 Center front member 520/1 520, 521 Pickup
54611-32500
99990-10036 Zx Bur.gd.bur $76.03 S130 280ZX
96500-23100 Ash Tray , $12.18 B110 1200
25210-14800 Switch,dimmer $12.51 520/1 520, 521 Pickup
G5930-89902 INSULATION PAD S30 240Z
23233-65561
76889-W6600 Ornament,d $14.67 A10 510
76962-U0100 Clip Retaining $1.60 B11 Sentra
87603-54A01 Stopper Assy,he $3.98
83248-U8100 Stopper,window $3.22
76958-01F00 Clip $2.25 S12 200SX
80222-34A05 Finsh,door Cnrh $9.11 B11 Sentra
87830-29R01 Escutcheon,shou $6.32 M10 Stanza Wagon
80673-21002
82297-Y1900 Bolt,guide Rail $2.23
87418-03P03 Knob Reclining $2.79 Z31 300ZX
93489-80W06 Plug Blind Blue $0.93 Pickup
79852-H6900 B210 B210
82550-17C00 Actuator,slide $224.22 GC22 Van
91714-15F00 Esctcheon,hinge $7.85 S12 200SX
80604-04E00 Handle Fr Dr Rh@ $58.79 U11 Maxima
87406-N8203 Knob Rec.dev Rd $3.20 S110 200SX
84958-11A02 Cover Lamp L $8.17 B11 Sentra
87405-P7901 Cvr Device In R $3.90 S130 280ZX
90464-11A00 Washer B11 Sentra
96409-N7801 Holder,sunvisor $2.82
87457-W1002 Cover
84945-21A02 Cvr Tail Lmp Lh $6.90 B11 Sentra
87406-N8205 Knob Reclining @ $3.48 S110 200SX
87602-50A02 Service File S $4.17 B11 Sentra
90575-21A00 Shim Adjust $1.94 B11 Sentra
87455-K0100 Cover Device Lh $7.32
84952-11A02 Cvr Shock Abs R $5.64 B11 Sentra
85036-N8511 Cvr Bmpr Rear $2.73 S110 200SX
92560-70A00 Grommet,rubber $4.08 B11 Sentra
16701-37504 Gasket Pump $1.22
22136-18005 Breaker Contact@ $23.58
41100-B5026 Kit Whl Cyl @ $9.52 620 620 Truck
44100-71225 Kit Whl Cyl @ $8.88
23120-04P10 Bearing,ball - alternator $11.41 Z31 300ZX
22157-03A00 Rotor Head $7.70 B11 Sentra
16196-U6000 Valve,antidiesl $39.75 L18-20
16079-23011 Gasket,cover $1.20
17089-G3900 Screw $0.90
08124-6951A Bolt Hex $5.31
18016-89926 Pad,accel Pedal $4.98
01456-00351 Screw $0.77
22472-17C09 Clamp $6.24 GC22 Van
01456-00041 Screw $0.54
00511-0020P Ring,o $1.01
08121-06028 Bolt Hex $1.76
21647-W2700 Clip Tube $13.68
00911-04710 Nut $0.92
18225-W8900
C2852-P9500 Sprngdetnt Pkg2 (only 1) $2.66 S130 280ZX
22102-A5500 Ignition Conden $4.71 S30 240Z
22102-U6003 Condenser @ $4.53
C2849-P9500 Pin Roll Pkg 10 (only 8) $2.31
C2817-P9500 Roller,cam $2.97 S130 280ZX
31940-80X25 Solenoid Repair $96.05 A32 Maxima
73630-15E00 W.strip,s.roof $135.34 U11 Maxima
87953-V5805 Cover,seat $13.21
93823-B9800 Board,splash Lh $11.97 620 620 Truck
62314-36A00 Fin,headlamp Rh $59.61 B11 Sentra
76922-40U10 Welt,body Side+ $61.95 A32 Maxima
25050-H7203 Assy,wire @ speedo cable $41.06 B210 B210
84932-H1800 Cover Lamp B110 B210, 1200
68752-80M00 Ventilator Assy $27.78 N12 Pulsar
21501-19W00 Hose,rad Upper $14.33 D21 720 Truck 2.0 & 2.4 engines
33169-C6900 Sping Shift Frk $2.13
43236-18000 GREASE CATCHER $3.01
13085-40F10 Timing Chain Gu $12.54 Stanza, Access, 240SX, Pickup KA24E
21750-17C20 Clamp,hose $1.24 GC22 Van
86475-N3700 Cover Device R 2+2 $10.74 S130 280ZX 2+2
13091-40F15 Chain Guide $53.84 Stanza, Access, 240SX, Pickup KA24E
32825-E4600 Spring,check reverse $0.78 S30 240Z, 4 speed
32845-18800 Ring,o, control arm $1.35 S30 240Z, 4 speed
73990-07A00 Cover S.window $1.59 B11 Sentra
90805-E4100 Striker assy, hatch $6.90 S30 240Z
32813-24901 Bracket,rod $11.79
32703-73701 Pinion,speedo $15.01
32851-14600 Spring,control $3.27 L16 transmission
85059-D1600 Box,rlh Marker $5.01 T11 Stanza
63874-50Y10 Moulding,front $20.46 B13 Sentra
39614-A9000 Bolt,side Flang $6.62
54308-A0825 Kit,seal Strut $26.85
96943-W1003 Finsh Consl Lid $4.48
65158-01W01 Bumper Hood $2.34 D20 720 Truck
84932-H1800 Cover lamp B110 B210, 1200
54308-A0826 Kit,seal
80870-H9121 Reinforce Assy $17.38 B310 210
62654-04A00 Plate Baf Core $2.91 B11 Sentra
68640-W5801 Striker Lock G. $6.21 A10 510
30610-08726 Kit. B Repair C/MCYL A10 510
29352-P7100 Escutcheon,baln antenna $1.89 S130 280ZX
38154-60401
40179-A8600 Nut, slotted hex , knuckle arm $3.81 240
76868-U0100 Bumper,door Re $1.29
76999-V5100 Clip,garnish $1.31
31932-X0103 Rod,diaphram, a/t $0.90 S30 240Z
41124-16505 Service File P $3.75
13028-8B000 Chain,timing $46.65 Stanza, Access, 240SX, Pickup KA24E
13070-40F06 Chain Tensn $65.70 Stanza, Access, 240SX, Pickup KA24E
13075-40F10 Bolt Tensioner $1.87 Stanza, Access, 240SX, Pickup KA24E
54613-M1000 N10 310
63143-N5800 Mldg,frt,finish $11.99 S10 200SX
31932-X0104 Rod,diaphram, a/t $0.90 S30 240Z
32853-03200 Boot,lever $2.43
32831-C6900 Spring Lock $0.96
68790-W7500 Grille Vent $14.09 A10 510
28177-57G00 Grille,speaker+ $8.28 D20 720 Truck
77700-89902 Plug @ $1.62
32268-H7302 Ring,snap $1.78 B310 210
67915-01P03 Cover,blue $6.86 Z31 300ZX
38321-H3000 Cover brea
86606-N9617 Button Blue $4.44
32268-H7300 Ring,snap $1.78 B210 B210
73631-W1011 Shim $1.41 A10 510
32354-H9000 Nut $9.77 B110 B210, 1200, 60 series transmission
55553-E4100 Washer, rear suspension, traverse link $1.35 S30 240Z
41005-16505 Nut,hex $0.72
32221-E9500 Spacer,counter $2.82 S30 240Z
73557-P8100 Washer Shade $2.27 S130 280ZX
96301-04A10 Mirror Outsid R $110.14 B11 Sentra
96301-14A11 Mirror Outsid R $83.37 VAR 280ZX , Sentra, 200SX, 240SX, Maxima, Stanza
68920-D1401 Cover,inst Drve $36.25 T11 Stanza
76960-N4600 Garnish,black $13.16 S30 280Z
54611-?????
80870-2B509 Service File M $61.26 B11 Sentra
72762-13E00 Mldg W.s Lwr @ $150.75 U11 Maxima
76451-H9120 Sill,inner Lh $79.35 B310 210
79121-P9900 Rr Panel Lwr @ $122.78 S130 280ZX
40315-37A00 Cap Road Wheel @ $43.86 B11 Sentra & Stanza
66911-N3000 Trim Dash R. kick panel $8.89 S30 240Z
92111-40F65 A/C condensor S12 200SX
85020-N8520 Bumper Ctr Rear $263.46 S110 200SX
79122-N8500 Rear Panel Lwr $104.24 S110 200SX
21475-H2300 Shroud,radiator upper $22.46 B110 B210, 1200
28830-13E22 U11 Maxima
63810-88400 Fender over
63811-88400 Fender over
80214-0B000 Sash Assy,front $9.92 V40 Quest
80821-H5002 Moulding Lh @ $40.17 B210 B210
93829-8B400 Fender,over+ Re wheel flare $36.43 D21U Pickup
31070-P7100 S130 280ZX
17509-60500 17509-60?00
99990-00900 moulding lip, coupe, 2+2 S130 280ZX
99990-00681 moulding lip rt $135.69
99990-00699 moulding lip
72810-H1106
65510-B9500 ROD-HOOD-SUPPRT $7.48 620 620 Truck
65432-N8201 bar S110 200SX
65433-N8201 bar S110 200SX
40315-S3550 trim ring kit 14" D20 720 Truck
28138-60A00 Speaker unit RH grill 71.76 B11
28174-60A00 Speaker unit RH bezel 29.67 B11
99993-00316 Radio face plate B110 1200
78822-U2000 "Datsun 1800" emblem 1800
68930-01G00 Cover Instrument LH $17.95
99993-00401 Radio Console B210 B210
93885-27W25 Accent Stripe -short body RH blue D20 720 Truck
Edited by zed1
  • Replies 10
Any physical descriptions or photos of these. Thanks
The descriptions are from the Nissan parts catalogue. I have not taken pictures of the 200+ parts. 95+% of them are in their original boxes or plastic bags.
Keith
Zed1,
The emblems arrived in fantastic shape. Great part, great price, and fast shipping - THANK YOU!
Looking forward to putting them on the car. :D
  • 2 months later...
  • 4 weeks later...
