Docsis510 Posted April 14, 2009 Report Share Posted April 14, 2009 so when i hit the alarm all my lights work. when i go to trun on the engine they just shut off. the only ones that work are the low beams, brake,turn signals. the ones that dont turn on are the high beams, license plate and all the fender and quarter panel lights. i checked the fuse box and all the fuses are good. i was wondering if any one might know whats going on? Quote Link to comment
banzai510(hainz) Posted April 14, 2009 Report Share Posted April 14, 2009 seen this before. WHOEVER put the alarm in routes the power thru the alarm system. Usually a switch box (inside the alarm)that puts ON/OFF power to makes light flashes when the alarm is tripped. I would hook it back up to stock if the MF didnt hack the wires up. Quote Link to comment
Pacific coast Datsun Posted April 14, 2009 Report Share Posted April 14, 2009 Remove alarm & toss in closest dumpster, return wiring back to stock [if poss.], install starter interupt kill switch & hide said switch in car, install a blinking LED light from Radio shack in dash that can be switched on & off..if you wanna :D Quote Link to comment
djmoreron Posted April 28, 2009 Report Share Posted April 28, 2009 Remove alarm & toss in closest dumpster, return wiring back to stock [if poss.], install starter interupt kill switch & hide said switch in car, install a blinking LED light from Radio shack in dash that can be switched on & off..if you wanna :D where can one purchase a starter interupt kill switch?!? Quote Link to comment
Pacific coast Datsun Posted April 29, 2009 Report Share Posted April 29, 2009 where can one purchase a starter interupt kill switch?!? Any Radio shack will have them :D Quote Link to comment
jonesy510 Posted May 4, 2009 Report Share Posted May 4, 2009 i just ran into a problem some wat like this today.. all my lights work but as soon as i switch to my high beams the head lights go out. im to tired to check out the fuses tonight but if all of them are ok wat would i check next? Quote Link to comment
banzai510(hainz) Posted May 4, 2009 Report Share Posted May 4, 2009 Cl all the fuses and make sure the contack on the fuses are clean. Then I would ck the relay on the strut tower. If lows work then then you put it on High and all the front lights go out. its usually in the realy. It swaps to a 2 wire ground. instead of one. Your high beam swithc at the steering wheel is OK since all the lights went off to its telling th relay what to do. If possible pull the connector off and reinstall it.at the relay Quote Link to comment
Lozer Posted May 6, 2009 Report Share Posted May 6, 2009 Not to steal this thread but a quick additional question for Hainz. If you turn on the high's and the wires heat up and the lights go out after a few moment then do you have a bad ground (or 2) or is the relay at fault ??? also if it's the ground could you give a tip as to where they are grounded. Quote Link to comment
banzai510(hainz) Posted May 6, 2009 Report Share Posted May 6, 2009 (edited) You have H4 lamps on the stock harness?????? 510lights the connector are all wired to the battery.This is stock wiring!!!!!!!!!! Ck this by getting a test light grod the alligator end. then put the sharp pointy part on the lamp connectors. The test light will light up. That means its wired correctly. This is with the Lights OFF during this Check!!!!!!!! So when you pull the switch it routes a ground to one of the connetors in back of the lamp. since the other side has power already on it it passes thru the element thus making light. Now remeber the LOWbeam lamp has 2 elements in there but one one will come ON wither its on Low or High. It goes from one side to the other. Highs when the High beam arm is pulled it puts a ground on the relay thus throwing another BIGGER contack to gound 2 grounds I think.(remember the light all have power on there) One to the one side of the High beam lamp. thus making the HIGHS turn ON. Edited May 6, 2009 by banzai510(hainz) Quote Link to comment
