tnip Posted August 11, 2007 Report Share Posted August 11, 2007 so i know the real answer for my question is "get a 5spd" but i'm curious if anybody has shimmed their shifter on a 4spd to get it to feel less... mushy and free. if nobody's done a write up then when i get around to doing that, today or tomorrow, in my 521 i'll get some pictures for anybody interested. Quote Link to comment
datzenmike Posted August 11, 2007 Report Share Posted August 11, 2007 You probably have this: http://i138.photobucket.com/albums/q251/datzenmike/CopyofA1.jpg[/img]"] the F4W36L type A, the infamous 'monkey motion' shifter. It has a two part rubber mount for the shifter. ANY thing that would stiffen it up would be good. Maybe take them out and make a set out of nylon or urethane on a lathe. An L 5spd, FS5W71B, had the type B shifter with nylon bushings that can be replaced and is a better overall set up: http://i138.photobucket.com/albums/q251/datzenmike/CopyofBtype.jpg[/img]"] The 521 4spd may be shorter than the 5spd so measure them. If it is shorter you might be able to use the shorter two piece drive shaft that comes with the later model truck 5spd. The 5spd was an option on the 620 trucks starting in '77 through '79. The '80 720 will fit as well but not the 4X4 as it has no speedo drive in it. Quote Link to comment
tnip Posted August 11, 2007 Author Report Share Posted August 11, 2007 thanks for the info. yes i have the type a "monkey arm". i'm gonna mess with it this evening, or more likely tomorrow, and see what i can come up with. Quote Link to comment
mklotz70 Posted August 12, 2007 Report Share Posted August 12, 2007 replace the rubber with delrin.....that will get rid of the slop!! :) Quote Link to comment
tnip Posted August 12, 2007 Author Report Share Posted August 12, 2007 well i was actually referring to the two points of connection below the shifter arm. idk exactly how to describe what i mean. i've looked at it quite a few times and have decided that with some properly sized washers i can get it to feel much tighter. my dad had a 620 like 15 years ago that he did the same thing in and said it was very simple and made a big difference in the feel of the shifts. i just hate that when it's in gear you can still move it around like it's in neutral. also i need something simple to work on to distract me from my brake issues... i need simple lil things to keep me motivated. Quote Link to comment
datzenmike Posted August 12, 2007 Report Share Posted August 12, 2007 Yes, on a 620 you could put in washers or replace the nylon clips but yours is different and has rubber pieces in it. But, hey, maybe you'll figure out something new! Good luck. Quote Link to comment
mklotz70 Posted August 12, 2007 Report Share Posted August 12, 2007 A good hardware store like an Ace Hardware will have nylon washers of different diameters and thickness Quote Link to comment
tnip Posted August 12, 2007 Author Report Share Posted August 12, 2007 ace hardware? ... did you mean to say home depot? :) i don't think there are any actual hardware stores near me... i'll have to find that out. Quote Link to comment
mklotz70 Posted August 13, 2007 Report Share Posted August 13, 2007 Hmm...HD isn't a hardware store, but they may have something. True Value is another "real" hardware store...at least they are around the Portland area. Quote Link to comment
tnip Posted August 13, 2007 Author Report Share Posted August 13, 2007 well the fact of the matter is that there are probably some real hardware stores left around here. i mean like a "mom and pop" type hardware store. and for that matter i recently found out there's an automotive parts store like 5 miles down the road instead of the 10 i been drivin to autozone... whoops.. haha. anyway i didn't get around to lookin at it today, i'll have to look at it tomorrow. Quote Link to comment
banzai510(hainz) Posted August 13, 2007 Report Share Posted August 13, 2007 I removed the pin with the E clips then I got a bolt and just tighten it up. That got rid of some slop. It ewas to hard trying to find thin washers to put in there to take the slop out Quote Link to comment
sjeff64 Posted August 14, 2007 Report Share Posted August 14, 2007 just my opinion but my slop problem was not just the bushing.it was also where the pin with the snap ring went through the tranny shaft I put a .02 shim on each side.and changed the bushing Quote Link to comment
