sdsurf Posted March 11, 2009 Report Share Posted March 11, 2009 What is a naps z motor worth? I have one in my 521 that I was told has good compression. I don't want it, I want to run L-series so what is a decent one worth? Complete, air cleaner to oil pan Quote Link to comment
rusty510 Posted March 11, 2009 Report Share Posted March 11, 2009 ill give you $50 if you deliver it :D Quote Link to comment
datzenmike Posted March 11, 2009 Report Share Posted March 11, 2009 What is a naps z motor worth? I have one in my 521 that I was told has good compression. I don't want it, I want to run L-series so what is a decent one worth? Complete, air cleaner to oil pan If it is a Z20E from a 200sx it will have the desirable 152.5mm long rods and flat top pistons (will bolt into the L20B and give 8.9? compression. Also the crank is fully counterweighted and is identical to the L20B. (at least the twp that I have were) Also the flywheel is a fairly rare 6 bolt 200mm and will fit a Roadster clutch. If it's a Z22 then the block and internals are pretty much an L20B but with larger bore and stroke. An L20B head and timing coveer a gear will fit to make it an LZ22 motor. Flywheel could be 225mm or 240mm. S0 worth more than $50 to the right person. Find an old L20B and swap parts on and sell it as a 'stroker' Z22. Quote Link to comment
hang_510 Posted March 11, 2009 Report Share Posted March 11, 2009 i want a Z24 bottom end (cheap though) Quote Link to comment
sdsurf Posted March 11, 2009 Author Report Share Posted March 11, 2009 Are they stamped on the side similar to L-series? Z22, Z20E, etc Quote Link to comment
420n620 Posted March 11, 2009 Report Share Posted March 11, 2009 (edited) L motors are on the right side, back top edge of block - passenger side Z motors are on the left side between exhaust manifold outlets - drivers side Edited March 11, 2009 by 420n620 Ratsun members luv pics so thats the reason 4 edit ;) Quote Link to comment
bonvo Posted March 13, 2009 Report Share Posted March 13, 2009 interested in this my possible fee z22 motor was pulled out from under me:( Quote Link to comment
sdsurf Posted March 13, 2009 Author Report Share Posted March 13, 2009 It is a Z20. I am going to pull it sunday and take pics... Quote Link to comment
