banzai510(hainz) Posted February 28, 2009 Report Share Posted February 28, 2009 (edited) after swapping out the trans with Datto510 and Bucket My slave cylinder whent out also. Had a chezzy rebuild kit. which more or less puts a another rubber seal at the end of the plunger, The org stays on there. The new rubber ring fits on the end of the little post. thats it. Hope it lasts, as I usually but new 521 slave clys also I have overheat proplems. Find out my intake bolts got loose. So remember to retighten stuff. Hope I didnt bend the head. But it never got too HOT!!!!!! Edited February 28, 2009 by banzai510(hainz) Quote Link to comment
hessianben Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) what happens when the intake bolts get loose? I'd imagine you'd lose coolant... Is that why the head may bend? Edited March 1, 2009 by datzenmike Quote Link to comment
Justin Posted March 1, 2009 Report Share Posted March 1, 2009 My 521 doesn't have an overflow tank- Perhaps they need them? (you covered that already I know, but my 521 w/no overflow always runs low on fluid...?) What good is it adding the weight/pressure of an old 'gasket' to a new one, as far as the rebuild goes?? Quote Link to comment
banzai510(hainz) Posted March 1, 2009 Author Report Share Posted March 1, 2009 it was loosing coolant from the watar passages. But ever so slightly, Sometimes they can SUCK water into the intake making it look like a bad headgasket. So always ck a few time after a engine install. Even I forgot, as my beater 510 I closed up the water passages and wont notice this. Quote Link to comment
datzenmike Posted March 1, 2009 Report Share Posted March 1, 2009 what happens when the intake bolts get loose?I'd imagine you'd lose coolant... Is that why the head may bend? Indirectly. Loose bolts can cause loss of coolant. If you don't notice the loss and keep driving the motor can overheat. Severe overheating can cause the head to warp. The only cure is to remove and have milled flat again. To prevent keep bolts tight and never, never, never allow an aluminum head engine to overheat. Fix all leaks. Change coolant anti-freeze every two years. If not sure about thermostat, throw away. They are cheap and it's likely old or the original anyway. Don't buy the $5 POS from China... spend $12-$18 on a good one. Do the math ... how much for a tow or milling the head + the bother + head gasket? I have one that if it fails, it stays in the open position. Quote Link to comment
banzai510(hainz) Posted March 3, 2009 Author Report Share Posted March 3, 2009 Fuck Now my clutch master went out yesterday!!!!!!! Rebestos ,made in taiwan!!!!!!!! Put another in Works great. get spares while they are still avail slaves and master cyl. Rockauto .com has very good prices. Most are made in taiwan now. Quote Link to comment
dreamers_vault Posted March 3, 2009 Report Share Posted March 3, 2009 its hard to get ori parts here now in malaysia...n the taiwan made was waaayyyy cheaper...here even got 1st grade n 2nd grade quality for taiwan product..:D Quote Link to comment
whitechef Posted March 3, 2009 Report Share Posted March 3, 2009 A few years ago I had an old Ford PU with a hydtraulic clutch that kept going tits up on me. It did it at work one day when there was no brake fluid around so I used tractor hydraulic fluid instead and drove the truck another ten years without ever having to mess with it again. The only thing I ever noticed was that on extremely cold mornings it was a little stiff but loosened up within 5 minutes of driving. Quote Link to comment
Andy Posted March 3, 2009 Report Share Posted March 3, 2009 Indirectly. Loose bolts can cause loss of coolant. If you don't notice the loss and keep driving the motor can overheat. Severe overheating can cause the head to warp. The only cure is to remove and have milled flat again. To prevent keep bolts tight and never, never, never allow an aluminum head engine to overheat. Fix all leaks. Change coolant anti-freeze every two years. If not sure about thermostat, throw away. They are cheap and it's likely old or the original anyway. Don't buy the $5 POS from China... spend $12-$18 on a good one. Do the math ... how much for a tow or milling the head + the bother + head gasket? I have one that if it fails, it stays in the open position. New guy here,Hi. ok i'm getting ready to change out the water pump on this thing.It will not hold anti-freeze long i hear a hissing from a hose need to find i did not think about the head bolts. Quote Link to comment
DatDoug Posted March 3, 2009 Report Share Posted March 3, 2009 FuckNow my clutch master went out yesterday!!!!!!! Rebestos ,made in taiwan!!!!!!!! Put another in Works great. get spares while they are still avail slaves and master cyl. Rockauto .com has very good prices. Most are made in taiwan now. WTF Hainz? Are you a spokesman for RockAuto or what:blink: You pimp those dudes constantly. Getting a kickback:D Quote Link to comment
banzai510(hainz) Posted March 3, 2009 Author Report Share Posted March 3, 2009 (edited) I liked Mr Auto-parts.com but they went defunct. I paid Schucks 35$ out the door for a new slave I havent recieved yet. then find Rockauto cheaper not including the discount. NAPA said NLA ,yeah right! But if you know of another source of parts let us all know. I cant find a cheaper place since Mr-autoparts went under. Mr Auto had over 50$ FREE shipping be honest I havent needed new parts in over 3/4 yrs untill this happened. Then it was all at once. Havent purchased anything from Motorsports also in about 4yrs Edited March 3, 2009 by banzai510(hainz) Quote Link to comment
ariascarlos1990 Posted March 3, 2009 Report Share Posted March 3, 2009 it was loosing coolant from the watar passages. But ever so slightly,Sometimes they can SUCK water into the intake making it look like a bad headgasket. You know what... I think thats why my truck smokes on the freeway. :eek: There are only the upper bolts in on my intake. :confused: Quote Link to comment
Andy Posted March 3, 2009 Report Share Posted March 3, 2009 New guy here,Hi. ok i'm getting ready to change out the water pump on this thing.It will not hold anti-freeze long i hear a hissing from a hose need to find i did not think about the head bolts. water pump good,We have a shop here call "Coconino Auto Parts" Better than NAPA,Checkers,AutoZone,Pepboys and others that i have come across.All they deal in is parts from 1940-2000 some newer but very little and all makes. Quote Link to comment
banzai510(hainz) Posted March 3, 2009 Author Report Share Posted March 3, 2009 Carlos if you dont have the lower bolts it definitely be leaking water. You must lave a L20 head with out the water passage. Usually the type where the intake is bolted to the exhaust manifold. or just dont have or use the water passage. PS also if its starts smelling underneath the hood its the intake/exhaust gasket as they will blow out underneath if not kept tight. Quote Link to comment
ariascarlos1990 Posted March 3, 2009 Report Share Posted March 3, 2009 ill check Quote Link to comment
ariascarlos1990 Posted March 3, 2009 Report Share Posted March 3, 2009 checked and my intake and exhaust both bolt up together. Quote Link to comment
