sycloned916 Posted October 3, 2009 Report Share Posted October 3, 2009 well got the cooling system done minus the fan wireing.... got the intake system started... need one more piece of intake pipeing and some couplers and im good there...ill take some pics later o and i also oredered the steering rod that clears the front sump oil pan from beebani so that will be done in a couple weeks I have some extra 2.5in alum piping and some straight couplers you can have the piping I have two straight,two 45 degree and one 60 or 70 degree pipe there about 18-20 in long. Quote Link to comment
620mike Posted October 3, 2009 Author Report Share Posted October 3, 2009 I have some extra 2.5in alum piping and some straight couplers you can have the piping I have two straight,two 45 degree and one 60 or 70 degree pipe there about 18-20 in long. ill pm u Quote Link to comment
620mike Posted October 5, 2009 Author Report Share Posted October 5, 2009 I picked up a 87 volvo wagon inline fuel pump today at PnP and maybe some one could tell me if i need a fuel preasure regulator with that or its just a bolt on thing...... and also do i need to replace all the fuel lines with fuel injection line or is the stock stuff ok? .... and also im almost done with my intake i just need to fab a bracket for my MAFS Quote Link to comment
butcherboyjc Posted October 5, 2009 Report Share Posted October 5, 2009 Hey mike, I used a Bmw in line fuel pump, and ran new 5/16 fuel lines both feed and return and a combination of rubber hose and hard lines. Also an inline fuel filter, the pressure regulator is on the fuel rail of the Ka, you should be ok with the stock regulator. Quote Link to comment
620mike Posted October 5, 2009 Author Report Share Posted October 5, 2009 (edited) cool that sounds good....and also i tryed the 720 throtle cable and its just not long enogh? i keep looking at my engine and it is way too close to the fire wall, i have to figure out how to get it off without changing up my whole set up....:( ok so im going to post a pic let me know what u guys think, looks like a mess right now.. i need to eliminate all the unnessacery lines and wires its really irritaing .. and i dont know what to get rid of either? Edited October 5, 2009 by 620mike Quote Link to comment
butcherboyjc Posted October 5, 2009 Report Share Posted October 5, 2009 The 240sx throttle cable is long enough to use and yeah it is a tight fit against the firewall. Quote Link to comment
620mike Posted October 5, 2009 Author Report Share Posted October 5, 2009 The 240sx throttle cable is long enough to use and yeah it is a tight fit against the firewall. so should i move the motor up or u think i can jack the trans up more to move it away from it enough? Quote Link to comment
butcherboyjc Posted October 5, 2009 Report Share Posted October 5, 2009 I was just agreeing with you that it was a tight fit cause it is the same with my engine and firewall. I think thats how all the KA's sit in the 620. Does the engine hit the firewall? Quote Link to comment
620mike Posted October 5, 2009 Author Report Share Posted October 5, 2009 (edited) ya im kinda worried its going to wear away.... shoot i didnt relize u were so close were going to have to meet up. i wouldnt mind checking out you ride also. Edited October 5, 2009 by 620mike Quote Link to comment
620mike Posted October 10, 2009 Author Report Share Posted October 10, 2009 got all the interior ecu wiring done.... but i have power in to all the relays but no power out from the realys.... is it because the engine wiring is not all complete (alt, starter.ect) but even if that was the problem.. wouldnt the fuel pump still come on? Quote Link to comment
sycloned916 Posted October 10, 2009 Report Share Posted October 10, 2009 Ya the pump should go on, when I had power to mine pump came on for a few sec's and I had power to all the relays in mine. I might be free later tomorrow I'll call you if I can make it out there but I'll be in the Syclone not the 520. Quote Link to comment
620mike Posted October 10, 2009 Author Report Share Posted October 10, 2009 I switched out the relays with diffrent ones and i got power now if i put power to the ecu, eccs, and fuel pump with the switches on im ok. but if i put power to it with the switches off and then flip them on the fuses blow.. are my switches not powerfull enough or just cheap? Quote Link to comment
sycloned916 Posted October 10, 2009 Report Share Posted October 10, 2009 I switched out the relays with diffrent ones and i got power now if i put power to the ecu, eccs, and fuel pump with the switches on im ok. but if i put power to it with the switches off and then flip them on the fuses blow.. are my switches not powerfull enough or just cheap? What switches are you talking about. Ignition? Igot my relays for tognoties 30amp with gold termanals. Quote Link to comment
620mike Posted October 11, 2009 Author Report Share Posted October 11, 2009 What switches are you talking about. Ignition? Igot my relays for tognoties 30amp with gold termanals. im talking about the on and off switches but i got some new ones and everything is working fine but my fuel pump is only pumping for about 15 sec and then turing off is that because its not got fuel runing through it? to get it to turn back on i have to pull the battery cable off then put it back on... well now i have to mount everything in and make it look clean then its on to engine wiring.... butcherboy offered his help tomorrow an i might take him up on it....... still dont have the fuel pump mounted permanent.. dont really know how i want to do it, 5/16 lines or 1/4 frame mount or fender well. still need to get a belt and a new fan because i guess my idea isnt going to work... Quote Link to comment
sycloned916 Posted October 11, 2009 Report Share Posted October 11, 2009 Hey Mike when I turn my key to on or the run spot the pump runs for about that to put pressure,then it turns off. If it sits for a few sec or a min it will do the same prime the line so fuel is in the lines. Try to see if it does that and is there fuel in the tank I don't think its good for the pump to dry run it too much. Should be fine. Quote Link to comment
620mike Posted October 11, 2009 Author Report Share Posted October 11, 2009 Hey Mike when I turn my key to on or the run spot the pump runs for about that to put pressure,then it turns off. If it sits for a few sec or a min it will do the same prime the line so fuel is in the lines.Try to see if it does that and is there fuel in the tank I don't think its good for the pump to dry run it too much. Should be fine. ya thats what my dad said so it must be true but im not sure how i want to mount my fuel pump and run the lines it has 1/4 right now and butcherboy (jaun) gave me the 5/16 to run a line so it shouldnt be a problem im just not sure how to go about doing that maybe jaun can give me some pointers tomorrow.... i might just go 5/16 in and 1/4 out and that should work? Quote Link to comment
sycloned916 Posted October 11, 2009 Report Share Posted October 11, 2009 That should be good the 5/16, I just went 3/8 because my filter is a -6an(3/8) so it would all be the same. You should be good. Quote Link to comment
620mike Posted October 12, 2009 Author Report Share Posted October 12, 2009 butcherboy (jaun) came over today and we takled some of my wireing and got the motor to turn over, just need to get the alt. wired in. i got to get the fuel pump plumbed in an some little stuff buttoned up and if the rain dosent stop me i should be rolloin by the end of the week.:D Quote Link to comment
butcherboyjc Posted October 12, 2009 Report Share Posted October 12, 2009 [/img] I cut the very end, the flared part, of the stock feed fuel tank bung and inserted -4AN (1/4") fitting tube sleeve and nut and 37 Quote Link to comment
butcherboyjc Posted October 12, 2009 Report Share Posted October 12, 2009 I know the exhaust collector is very close to ground I have to re-do the whole exhaust.:) Quote Link to comment
620mike Posted October 13, 2009 Author Report Share Posted October 13, 2009 got all the fuel fuel fittings ill be doing the fuel system rain or shine tomorrow went to pull my tank tonight but couldnt get enough lite out there. maybe i can get out there early enogh before the rain starts.... i want to fire it up tomorrow:D Quote Link to comment
620mike Posted October 15, 2009 Author Report Share Posted October 15, 2009 got the truck fired up today sound pretty good got some other stuff to button up but its commin together good Quote Link to comment
sycloned916 Posted October 16, 2009 Report Share Posted October 16, 2009 That was fast,what are you using for a muffler on it. Quote Link to comment
620mike Posted October 17, 2009 Author Report Share Posted October 17, 2009 nothing right now but it sounds heathly underneath the noise of the header lol ....going to get exhast done by my buddy at marco muffler the first time i put it on the street. its going to have a magnaflow just like everyone else but im running it all the way back with z06 tips in between the tail light buckets, with flame thrower kits.... should be pretty cool Quote Link to comment
sycloned916 Posted October 19, 2009 Report Share Posted October 19, 2009 Ya drive it? Quote Link to comment
