DaveyDaveDaveDave Posted February 27, 2009 Report Share Posted February 27, 2009 I just got the XR700, like $100 from summit (I know, doubles the value of my truck, but shes real special and totally worth it, the cheeky ole gal!) Looks easy as hell, but Im gonna take some pics as I go in case theres anything interesting down that road. If there is, I'll post a short writeup and let you all know how it goes and if imho its worth the dough. Currently I have a miss that no amount of fixin has...fixed. New plugs, wires, cap, rotor, accel supercoil... Still misses. could try cleaning the dizz, but that makes too much sense:D PS, its a 78, so it has the transistorized dizzy. Quote Link to comment
moparvwfreak Posted February 27, 2009 Report Share Posted February 27, 2009 remote style or matchbox? if its a matchbox i have a couple control units. Quote Link to comment
mklotz70 Posted February 27, 2009 Report Share Posted February 27, 2009 If it's the matchbox...are you running a ground wire to the body of the dizzy? Run one from the screw that holds the vac adv to a good ground if you don't already have one. Quote Link to comment
DaveyDaveDaveDave Posted February 27, 2009 Author Report Share Posted February 27, 2009 Its not a matchbox, its the stock 78 distributor. 77 was a mixed year for mechanical and transistorized, in 79 they went matchbox, or as the haynes manual Im looking at calls it, IC ignition. Anyhow, im throwing in what is basically a hall effect. I opted for the cheap unit (xr700, not xr3000) in hopes that it cures a miss and looks badass. Its about time something under the hood was badass... Quote Link to comment
banzai510(hainz) Posted February 27, 2009 Report Share Posted February 27, 2009 the XR700 was a Allison Point conversion the Crane Cams bought them out. its more or less uses a tranisitor box and a light opital pick up with a shutter disc. The kit will have assortement of shutters and you rig it up to the distributor shaft. http://catalog.eautopartscatalog.com/archsoftware/importedcarpartspfp/wizard.jsp?partner=pacific&year=1977&make=NI&model=PUP-620-003&category=F&part=Ignition+Conversion+Kit&partnerSession=98956858f0a5c6b411c6b70611f70918 To me it clutters up the engine bay(the box and 3 or 4 wires) but they have good reliability from what was written thru the years. I believe you still use the ballast resisitor and stock coil. I think the pertronix is cheaper and is a cleaner set up if you grind off the ring above the l20 point lobes. ezest way is just buy a matchbox dizzy Quote Link to comment
