jrbd10 Posted February 19, 2009 Report Share Posted February 19, 2009 (edited) Thanks to fellow member natin, I now have some side drafts. I plan on getting new fuel lines, and a mild to hot cam. Any other reasonable suggestions? I have exhaust already and trying to get some more torque or horses for my buck. as it stands around 3,000 rpms and it makes a weird clicking sound. My friend tells me it might be something internal any thoughts? Edited February 19, 2009 by jrbd10 Quote Link to comment
bagged_datsun Posted February 19, 2009 Report Share Posted February 19, 2009 that ticking sounds like and exhaust leak Quote Link to comment
datzenmike Posted February 19, 2009 Report Share Posted February 19, 2009 If it changes volume with throttle it's exhaust. If it's there all the time and stays the same volume it's a valve clearance. If it comes and goes with rpm it could be a loose chain or bad tensioner/chain guide. Quote Link to comment
jrbd10 Posted February 19, 2009 Author Report Share Posted February 19, 2009 ok Im hoping its just the exhaust. but what about a mild cam or a hot cam is this a good idea? Quote Link to comment
SIXTY-NINE-DIME Posted March 18, 2009 Report Share Posted March 18, 2009 Thanks to fellow member natin, I now have some side drafts. I plan on getting new fuel lines, and a mild to hot cam. Any other reasonable suggestions? I have exhaust already and trying to get some more torque or horses for my buck. as it stands around 3,000 rpms and it makes a weird clicking sound. My friend tells me it might be something internal any thoughts? im having the same problem. mine makes the same exact noise and the tick goes faster when i rev it. i thought the valves needed to be adjusted but it might just be an exhaust leak?? Quote Link to comment
izzo Posted March 18, 2009 Report Share Posted March 18, 2009 Mine ticks to, faster when the engine is revved. Im pretty sure its my lifters, i just dont know how to adjust them, yet (i did read the how to just havent attempted it yet) there is some blowby on mine too. Quote Link to comment
datzenmike Posted March 18, 2009 Report Share Posted March 18, 2009 A solid lifter will tap all the time from idle up. Usually more noticeable when the rest of the engine is quieter at idle. Varies with engine speed. Exhaust leak becomes louder as you increase the load on the engine and it works harder. Varies with engine speed. A noise that only occurs at a set RPM could be worn/loose/slack timing chain/tensioner. 720s have been known to do this at idle when oil is low or needs changing. The tensioner is fed with oil which combined with the internal spring forces the shoe out against the chain to tension it. Any drop or lack in oil pressure will slightly affect it. A Z24i oil pump will help idle oil pressure. Quote Link to comment
SIXTY-NINE-DIME Posted March 18, 2009 Report Share Posted March 18, 2009 ya im pretty sure its my lifters to. it sounds like its coming straight from the head Quote Link to comment
bonvo Posted March 18, 2009 Report Share Posted March 18, 2009 ok Im hoping its just the exhaust. but what about a mild cam or a hot cam is this a good idea? if your keeping it l series and you want the most power and tourqe have the head ported and polished have bigger valves put in it if possible do this on a closed chamber head a hot cam will only give you power at higher rpm i would get a mild one so you have power where your gonna use it so far everything ive said is head related build the head then take the head after its built and get build an lz2.2 using l20b parts this is the biggest displacment l series motor your gonna get without having to weld aluminum remember there is no replacment for displacment Quote Link to comment
