ichorid Posted February 10, 2009 Report Share Posted February 10, 2009 (edited) Hey guys, so I am going to be giving the engine bay of my 510 a good scrub down this weekend, and I was planning on sanding down and trying to slow some seemingly bad rust spots. I found this online http://www.gemplers.com/product/127787/Spray-on-Rust-Converter but it sounds a little to good to be true, nothing can just spray and make my worries go away. Other than easy cheese. is it just like por15? any of you ever use this stuff? I think Ill just stick to the local home depot supply of http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100171058&N=10000003+90048+1684 I have used it before after sanding and cleaning metal surfaces and it treated me well. Just never really seen anything that claimed it turned rust in to beneficial anti-rust primer. well if any one has had any experiences with the stuff let me know I may order some when I gut the interior if its any good. here are pics of the rust for views and ref. thanks, -casey Edited February 10, 2009 by ichorid Quote Link to comment
veryboard Posted February 12, 2009 Report Share Posted February 12, 2009 I have used Rust Check`s rust converter with pretty good results.I painted the inside and outside of a cast iron pool pump about 5 years ago with this stuff and still looks not bad.Out side looks really good inside flaking off a bit. I did the back half of my 521 frame last year it still looks the same as it did when I sprayed it,and I never even got any paint on it.I plan on doing the hole frame this spring.Here is what I do wire wheel the rusted areas best you can,then spray with the rust converter.It may take two applications all depends on how rusty the area is.Once it is dry it turns to a different colour and is ready for paint no additional primer required..This coating stop the rust(not forever) and gives you a paintable surface.I use all the time now.Check out a can can`t hurt can it. Quote Link to comment
]2eDeYe Posted February 12, 2009 Report Share Posted February 12, 2009 Look into POR 15 as well. I second wirewheeling any crusty, flakey areas. Sand paper for the light stuff, should be able to get rid of a lot of it. Your truck actually doesn't look to bad. Looks like it blew a radiator hose...or maybe the whole radiator. Quote Link to comment
Z-train Posted February 12, 2009 Report Share Posted February 12, 2009 POR-15+fibrglass & follow the directions.The rust in the pictures will be an easy target for POR-15 Quote Link to comment
Z_Rac3r Posted February 12, 2009 Report Share Posted February 12, 2009 Good to know this kinda stuff works Quote Link to comment
hang_510 Posted February 12, 2009 Report Share Posted February 12, 2009 http://www.gemplers.com/product/127787/Spray-on-Rust-Converter but it sounds a little to good to be true, nothing can just spray and make my worries go away. Other than easy cheese. is it just like por15? if it sounds too good to be true, it usualy is! mmmmmm aerosol cheese :drool: id stay away from that spray brand, very little chemical content based on the MSDS. look for something w/ phosphoric acid. and def remove as much as possible. the stuff works though. its NOT at all like por15, which you should apply afterwards. and none of them fill holes or replace missing metal (battery tray area) Quote Link to comment
phatdave Posted February 12, 2009 Report Share Posted February 12, 2009 Thats not bad rust. Bad rust is when you have ,what is called, section loss. When the large metal members ( hehe) start to come apart. That looks like mild surface rust. Some Naval Jelly and a wire brush should take care of it. Quote Link to comment
