littlekeeley Posted February 7, 2009 Report Share Posted February 7, 2009 anybody know about getting a new / used crank pulley for an L motor? its going on my L16, but i hear its universal unless im misinformed. if anyone can point me in the right direction, or to someone thats parting out before i can get out to a pull it yard, it would help me out a bunch! Quote Link to comment
datzenmike Posted February 7, 2009 Report Share Posted February 7, 2009 Pretty sure all these will physically bolt up: the Z24i on D-21 Hardbodys, Z24/Z22/Z20 in 720s and Z20/Z22 on '80-'83 200sx should work too. Don't use the 240/260/280z/zx car pulleys, they are offset differently and the water pump/alt. pulley won't line up. I checked part numbers and there's dozens of them. Probably slight variations in diameter and up to 3 pulley grooves depending if air pump, p/s pump, air conditioner pump, clutch fan or regular fan. From '71 up the same front oil seal is used all the way to '88 also the same pulley mounting bolt. I'm pretty sure it will bolt on, you will have to trial and error to get the correct belt length. Quote Link to comment
datsunaholic Posted February 7, 2009 Report Share Posted February 7, 2009 Well, they're not EXACTLY universal, as the timing mark locations differ AND there are various pulley configurations. They're "Rare" (not really) but it's not something that's generally considered a replacement item. Usually when you break one that's not the only part that broke, and while not impossible it's not exactly easy to lose. Though my Uncle watced someone lose one (off a Toyota) in the middle of a downtown street and it went rolling at a good 30MPH right down into an underground parking garage... Quote Link to comment
Skib Posted February 7, 2009 Report Share Posted February 7, 2009 Though my Uncle watced someone lose one (off a Toyota) in the middle of a downtown street and it went rolling at a good 30MPH right down into an underground parking garage... :eek::eek::eek: Quote Link to comment
datzenmike Posted February 7, 2009 Report Share Posted February 7, 2009 I was being towed once and I watched my drivers side rear axle with tire pass me.:eek: friggin Cutlass :fu: Quote Link to comment
banzai510(hainz) Posted February 7, 2009 Report Share Posted February 7, 2009 get a L16 pully as most are the 5 notch type and use a single pointer on the front cover. some are single or dual pulley type but botth will work. Im sure Jeff Hino or Datsunaholic have a stack of them. PM them Quote Link to comment
