FS: 720 4X4 drivetrain
I currently have what remains of a 720 4x4. It ran ( I began dismantling a few things in order to pull the motor, all of which can be reassmebled) tho it needs a good battery and a radiator. Z24 block, 5spd trans etc. There is nothing left of the interior for the most part.
All i see be worth anything on this is the drivetrain. Will sell in whole or part out.
  • Replies 12
The passenger side shaft is likely toast. The boot at the hub is basically non existent and the shaft slides into the diff while the drivers does not so im guessing that joint is blown. I took some pics if u wanna see.
$100 bucks.? not certain what its worth tbh but it was free to me.
If you wanna make the drive out here and take a look for yourself thats fine too. I wont be able to ship or deliver this either.
If you can tell me how to check without pullin the sumbitch apart, ill do it and let you know..I dont have extensive knowledge or experience with these trucks let alone a 4x4. I can tell you that is has the locker hubs (i believe) lil knob thing you twist...
