Windshield compatibility
Hey guys I have a 79 210 wagon that I'm trying to find a windshield for. I've been looking through the forum and the rest of the internet trying to find out if any other models/years will fit the same. If anyone has any info I would really appreciate it
  • Replies 4
I don't know if they are the same, but you could look at the 1st gen Sentra (B11 1982-1986). It replaced the 210, so it might have similar dimensions.
You could also look into a custom windshield, although that will get pricey.
I would expect you can only use a 210 windshield.  Example......the earlier 68-73 510 WAGON did use the same glass as the 2dr & 4dr Sedan, so hopefully you can use any 2dr 4dr or Wagon 210 glass.......??
Have you tried Mygrant Glass??  They are a national franchise, so you may well have one regionally.  They do sell the earlier 510 & Z car glass, so maybe they have the later 210............??
  • Thanks 1
The coupe is an exact swap, the sedan is different but it may be minor such as a radio antenna inside? slightly thicker?
The B11 are all different part numbers.
