Supercharged Body Swapped 1992 WD21 Pathfinder.
I am just getting all my projects out there for you folks to see.
This one started in 2013 when I purchased a 1986.5 Long Bed HD V6 Hardbody with a poor running engine. I parted the truck out and saved many good bits, including the cab. In 2018 I purchased a 1992 WD21 Pathfinder with a blown engine and front end damage for $250. From there I chopped the body off and dropped the 86.5 cab on to it. I ended up swapping it to 5 speed and dropping in a VG33ER from an 2003 Xterra in it. It is still running the VG30e ecm and has been a bit of a hassle to get running but last summer I figured it out and had it running solid. Still a ton of work to do but it is way past the bare frame it started as. It's name is Double Dare XL and I plan to have it finished, registered and on the road this Summer.
Double Dare XL, my other huge project...
Running but before I replaced the injectors and did some minor tweaks. 6psi.
The day the cab went on to the frame.
The entire 70+ video series can be seen here...  Video#5 is when the project really takes a turn.
Edited by Pounding Rox Truck Shop
  • Thanks 1
  • Replies 20
1 hour ago, Pounding Rox Truck Shop said:
Check out the RC truck by Kyosho, the Double Dare. Mine is kind of a hat tip to that thus the XL for Xtra Large. The wheels are pretty damn close too.
rad
99998: Kyosho from Dante77 showroom, Kyosho Double Dare 4WDS - Tamiya RC &  Radio Control Cars
I have the same wheels on my cj5
  • 4 weeks later...
Looks like I am replacing the power steering pump. Too many times run dry while getting the engine to run in the first place. It runs and drives now but the pump suffered. I guess I wasn't thinking because of the pure shock this thing ran in the first place.
  • 3 weeks later...
  • 3 weeks later...
I ordered some stuff to relocate the FPR from the end of the fuel rail to the firewall. I also ordered an Aeromotive adjustable FPR with boost reference. These OEM Nissan FPRs are junk when it comes to a project like this. With the new FPR I should be able to control things a little bit better. So off comes the blower again, and hopefully for the last time for a long time!
The latest on the project. When you hit a wall you can try to climb it or smash through it. This project has dragged on for so long I have now taken to smashing instead. I am writing the book on this, there is no guide and each step reveals new challenges to figure out. I will have this thing done and done to the best I can.
So I got everything installed on the fuel pressure regulator side of things. It went smooth. I have the 90deg fitting on the end of the fuel rail which deletes the OEM regulator and allows me to send fuel to an external boost-referenced manual regulator with a gauge mounted on the fire wall. Only hang up is I damaged gaskets taking the blower off. Actually, the number of times I have had the blower off has stressed the gaskets. I ordered a new set. Once the blower is back on we can test it again. Fingers crossed.
YT vid is coming soon.
Did you do a body lift to clear the super charger?  I've always wanted a VG33R in my D21!  Or basically anything with more power then the Z24 haha.
Yes, it has a 3" body lift. And I feel you on the z24. I have one and it's quite slow. I enjoy the truck it's in but I think a VG33ER would solve the power problem.
Update: The blower is back on and the truck is registering fuel pressure on the gauge. Will key it over later this week to see how it acts now.
  • 1 month later...
Finally had the bandwidth to turn the key on this project. It took a lot to prepare myself for more failure but to my surprise I got a WIN!
I did have a power wire pop out of its crimp after this video which led to chasing a no power at all situation but I did finally get that fixed and was able to continue moving around the yard. It runs and idles beautifully now!!
  • 1 month later...
