BrianBColo Posted March 11 Report Share Posted March 11 I have a '78 620 and having fuel system issues. Looking for a good mechanic in northern Colorado who understands these trucks. Thanks. Quote Link to comment
datzenmike Posted March 11 Report Share Posted March 11 We have a guy somewhere in Co.... https://ratsun.net/profile/4544-yenpit/ Meanwhile what does it do or not do??? May only need a fuel filter. Quote Link to comment
BrianBColo Posted March 13 Author Report Share Posted March 13 I have replaced the carb, fuel pump (mechanical), fuel filter, put in a backflow valve, and replaced all of the fuel lines and clamps. I also removed the tank, cleaned it out and replaced the sender. If I prime the carb, it starts, but when I shut it off, it won't start again. And the glass fuel filter empties out, and it never really fills to the top. When it stops, the drains back into the tank. Is there a vacuum issue? Quote Link to comment
datzenmike Posted March 13 Report Share Posted March 13 In a carburetor, once the gas is in the fuel bowl it can't magically jump up hill past the needle valve and return to the tank. It must be draining into the intake and why it's hard to restart. Next time you shut it off, pinch the rubber hose closed with vice grips. Bet the gas still magically disappears. Quote Link to comment
BrianBColo Posted March 14 Author Report Share Posted March 14 I have replaced the carb, fuel pump (mechanical), fuel filter, put in a backflow valve, and replaced all of the fuel lines and clamps. I also removed the tank, cleaned it out and replaced the sender. If I prime the carb, it starts, but when I shut it off, it won't start again. And the glass fuel filter empties out, and it never really fills to the top. When it stops, the drains back into the tank. Is there a vacuum issue? Pinch which rubber hose? Quote Link to comment
BrianBColo Posted March 14 Author Report Share Posted March 14 Pinch which rubber hose? Quote Link to comment
datzenmike Posted March 14 Report Share Posted March 14 Miss read. Fuel filter emptying doesn't matter. The carburetor will have enough gas in the float chamber to start and drive half way round the block. Filter siphoning back to tank is likely a loose hose clamp letting air in allowing the furl to flow sown hill. Check all hose clamps at the pump inlet and both sides of the filter. Quote Link to comment
Stoffregen Motorsports Posted March 14 Report Share Posted March 14 Are you pumping the throttle pedal before you try a cold start? Quote Link to comment
Stinky Posted March 15 Report Share Posted March 15 I bet it is your carb....as already mentioned. I really, really doubt that your fuel line has anything to do w/it. As mentioned, pinch your rubber fuel line, that will stop a back siphon (which can't be there because of the check valve). I bet your PU sill start if you hold your foot on the floor, while cranking it (it is flooded, and that fixes flooded as gives it air for the excess gas). My guess, is that you have a crack, or a pinhole allowing the gas to drain. Those things aren't rockets they are really simple to work on. Quote Link to comment
BrianBColo Posted March 15 Author Report Share Posted March 15 Yes, it starts when I floor it and idles and runs when warmed up. I shut it off and won't start. The carb is new, but could be leaking. I'll clamp the hose and see what happens. Fuel pump could also be bad (even though new) and thinking of replacing with new electric. Any recs on a fuel pump for a '78? Quote Link to comment
BrianBColo Posted March 15 Author Report Share Posted March 15 And I'll recheck all hose clamps. More to follow and thanks everyone. Quote Link to comment
datzenmike Posted March 15 Report Share Posted March 15 There should be lots of gas in the carburetor for restarting. So tightening the clamps may stop gas from siphoning back into the tank on the tank side of the fuel pump but this will have no effect on hot restarts. Gas cannot siphon back through the fuel pump. There are two one way valves inside. There is a one way valve at the fuel tank but it's there to prevent gas running out in the event of a roll over. Next time you have it running take a look at the front window on the carburetor. Where is the gas level??? It should be at the half way point on the small round glass window. This is important as it is designed to work properly at this half point. Look down inside. Do you see any dripping gas??? Shut it off and look. Anything? Quote Link to comment
Stoffregen Motorsports Posted March 18 Report Share Posted March 18 Floor it on a hot start and see if that gets it to fire. Quote Link to comment
