high winder Posted February 20 Report Share Posted February 20 What did the B210 Sedans use for trunk lid support ? Was it a strut like the hatchback Quote Link to comment
bilzbobaggins Posted February 20 Report Share Posted February 20 torsion bars I would assume. Quote Link to comment
high winder Posted February 21 Author Report Share Posted February 21 Any way too make them stronger so the trunk stays open when you want it open Quote Link to comment
iceman510 Posted February 21 Report Share Posted February 21 Replicate the torsion bar with larger diameter to increase the spring force. Quote Link to comment
datzenmike Posted February 21 Report Share Posted February 21 Two horizontal J shaped torsion bars under the rear windows with the bottom of the Js overlapping in the center. You'll have to use some form of lever to force the C end away from you and slip a piece of rubber (like a piece of tire tread) in where it pinches and normally would rest. You may only have to do one to get the extra torsional force to hold the lid open. Quote Link to comment
high winder Posted February 21 Author Report Share Posted February 21 Thanks fellas, I’ll give it a go Quote Link to comment
