rosso Posted February 11 Report Share Posted February 11 This is just about the last thing I need to get working. All the major electrical is complete and car runs fine - even out at Pacific Raceways for lapping with the Alfa club. I bought a new motor as pictured and the wiring diagram I have shows two wires to it - Blue/Red and Black/Yellow. I have no power to either wire with the ignition on acc. Wipers work but nothing to the pump. I need to get a couple of new connectors for the pump because the wires are so tiny and then plan to connect it. Red to Red/Black and the Blue to Black/Yellow. Does that seem right? Thanks again to all the electric geniuses, you.ve gotten me through it all. Quote Link to comment
datzenmike Posted February 11 Report Share Posted February 11 The Blue/Red has power any time the ignition or accessory position is on. The Black/Yellow goes to the wiper switch and is connected to ground in the 'wash' position to turn the pump on. It may pump if wired backwards in reverse. I would test the pump to see which way makes the pump work best and wire it in accordingly. 1 Quote Link to comment
MikeRL411 Posted February 11 Report Share Posted February 11 A new pump is the best way to solve washer problems! Often the low cost to buy one is to buy a new WW assembly and throw away the tank. Quote Link to comment
rosso Posted February 24 Author Report Share Posted February 24 Wired and working! Thanks all - just need to aim them. 😱 Quote Link to comment
