Brns73 Posted December 23, 2023 Report Share Posted December 23, 2023 I apologize if this question has been posted before. I’m installing an R160 diff into my Triumph. The diff is a3.54 ratio, out of a WRX. Because of the rear suspension design of my car, I have to use 510 stub axles with the “through bolt and cookie design”. I want to install a clutch type LSD unit in the diff. my question is, who sells a clutch type Limited slip unit for an R160 that will allow for the installation of the 510 stub axles? thanks in advance! Quote Link to comment
iceman510 Posted December 28, 2023 Report Share Posted December 28, 2023 On 12/23/2023 at 10:09 AM, Brns73 said: 510 stub axles with the “through bolt and cookie design”. I want to install a clutch type LSD unit in the diff. my question is, who sells a clutch type Limited slip unit for an R160 that will allow for the installation of the 510 stub axles? thanks in advance! I guess Quaife does make R160 units, but I'm pretty sure they will not work with stock Datsun axles. Quote Link to comment
thisismatt Posted December 28, 2023 Report Share Posted December 28, 2023 Look for the older Subaru R160 LSD with the bolt in stubs. These would be from ~1985-89. Quote Link to comment
datsunfreak Posted January 16 Report Share Posted January 16 On 12/23/2023 at 9:09 AM, Brns73 said: my question is, who sells a clutch type Limited slip unit for an R160 that will allow for the installation of the 510 stub axles? On 12/27/2023 at 11:26 PM, thisismatt said: Look for the older Subaru R160 LSD with the bolt in stubs. These would be from ~1985-89. What he said. Subaru did. If you have any junkyards nearby with older (80s) Subrarus, it's worth a look. They often had foil tags on them denoting whether it is a CLSD or VLSD and the ratio. Best to avoid the VLSD, though. Quote Link to comment
