Tommy Dat Posted December 12, 2023 Report Share Posted December 12, 2023 Good Day All, I am rebuilding my Hitachi DCH340 from my '80 720 and I think that someone has already fiddled with it in the past. I don't know enough to tell if differences are modifications or just omissions. The carb on the left is the one I took off and started to rebuild. The carb on the right is a DCH340 that came off of my '77 200sx. The power piston on the right has a spring and my instructions for the rebuild show that spring. The carb on the left does not have that spring. I figured I would just scavenge the spring from the pic on the right but I cannot figure out how to remove the assembly? Although both carbs have DCH340 engraved I can tell that there are some minor differences (maybe early/late models?) Do I need that spring for my rebuild on the left? what is the trick to remove it from the one on the right? thanks Quote Link to comment
Tommy Dat Posted December 12, 2023 Author Report Share Posted December 12, 2023 the pic did not post? the URL box turns red once I submit. I will keep at it, sorry Quote Link to comment
Tommy Dat Posted December 12, 2023 Author Report Share Posted December 12, 2023 Quote Link to comment
Tommy Dat Posted December 12, 2023 Author Report Share Posted December 12, 2023 1 minute ago, Tommy Dat said: I have circled in yellow the assembly that I am talking about, thanks for any help Quote Link to comment
datzenmike Posted December 12, 2023 Report Share Posted December 12, 2023 It's just a plunger. The removable power valve is at the bottom back of the float chamber. Pretty sure that part circled is staked in place and not removable Quote Link to comment
Tommy Dat Posted December 12, 2023 Author Report Share Posted December 12, 2023 thanks, so I do not need to have a spring on it? it does pump in and out like it may have an internal spring. Quote Link to comment
datzenmike Posted December 12, 2023 Report Share Posted December 12, 2023 The spring is there for a reason so yes it needs it. You might use a dremel to remove the staking holding the good one in place and get it out. When swapped to the '80 carb body you'll have to punch around it to displace metal to hold it in place. Or... Swap the carb bodies. Quote Link to comment
None_zero Posted December 19, 2023 Report Share Posted December 19, 2023 Just now, None_zero said: Just saying.... Quote Link to comment
Thomas Perkins Posted December 19, 2023 Report Share Posted December 19, 2023 Hey Homie.Where in Georgia do you live?I am a few miles down the road from Columbus. Quote Link to comment
datzenmike Posted December 20, 2023 Report Share Posted December 20, 2023 Follow the burn barrel smoke. Quote Link to comment
720_Jeff Posted December 20, 2023 Report Share Posted December 20, 2023 34 minutes ago, datzenmike said: Follow the burn barrel smoke. Or, smoke from the Jacuzzi. Just thought, he's probably using the burn barrel to heat the Jacuzzi. Thrifty Quote Link to comment
DwayneOxford Posted December 20, 2023 Report Share Posted December 20, 2023 On 12/11/2023 at 10:50 PM, datzenmike said: It's just a plunger. The removable power valve is at the bottom back of the float chamber. Pretty sure that part circled is staked in place and not removable You can depress it and let it snap up a few times and it'll come right out. Have to re-stake it then. Quote Link to comment
