DwayneOxford Posted November 19, 2023 Report Share Posted November 19, 2023 Anybody know good source? Quote Link to comment
Thomas Perkins Posted November 21, 2023 Report Share Posted November 21, 2023 Is air coming thru it? Quote Link to comment
DwayneOxford Posted November 22, 2023 Author Report Share Posted November 22, 2023 Took it out trying to figger rain leaking through it, it's shot. Quote Link to comment
datzenmike Posted November 22, 2023 Report Share Posted November 22, 2023 Likely you have pine needles and maple keys and leaves tapped in the air plenum where the wiper linkages are. The space under the louvers between the back of the hood and the windshield. They can plug up the drain on either side and water collects and over tops the duct down into the fan under the glove box. 2 Quote Link to comment
DwayneOxford Posted November 22, 2023 Author Report Share Posted November 22, 2023 Got the leak figgerd and stopped. Had to caulk around the ??? that sticks up over the heater intake. Took blower box off investigating leak. Foam tape around the inlet and outlet is shot, got to replace. Don't know exactly what it is, closed or open cell?? Or how thick oem was?? And the gasket around the blower motor flange is shot too. Washered out the nylon bushing on the flapper lever, got it shutting tight shut both ways. Quote Link to comment
Stoffregen Motorsports Posted November 27, 2023 Report Share Posted November 27, 2023 I use foam tape which I buy in rolls from McMaster Carr. The wide foam is used to make new foam seals for the flap doors, and the thin foam is used around the spots where it needs to seal to the other boxes and to the body. 1 Quote Link to comment
DwayneOxford Posted November 28, 2023 Author Report Share Posted November 28, 2023 Thanx! Can you kindly post their PN? Quote Link to comment
Stoffregen Motorsports Posted November 28, 2023 Report Share Posted November 28, 2023 Here is the product page. There are many different thickness and width options - https://www.mcmaster.com/catalog/129/4033/8694K129 I use this for where the boxes meet the other boxes. 8694K72 This stuff for thew flapper doors. 8694K129 Where it meets the body, there may be more room to play with, so you might want thicker material than the 3/16" posted above. You may want 3/8" or even 1/2". 1 Quote Link to comment
DwayneOxford Posted November 29, 2023 Author Report Share Posted November 29, 2023 Thanx agin. Quote Link to comment
