builte Posted September 22, 2023 Report Share Posted September 22, 2023 I found these 3 row radiators online for the 720 by spawon has anybody ever used them I'm skeptical because I don't think spawon even makes anything for Nissan or if this would even work? https://www.ebay.com/itm/133970382491?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=2vSNdoczQ_S&sssrc=4429486&ssuid=1g-do-ebrve&var=&widget_ver=artemis&media=COPY Quote Link to comment
datzenmike Posted September 22, 2023 Report Share Posted September 22, 2023 Good price! The stock is double row? I can't remember but it is much larger (L&W) than the earlier Z22 but thinner. 1 Quote Link to comment
builte Posted September 22, 2023 Author Report Share Posted September 22, 2023 Do you think it will work fine? All the hookups seem to match mine I pulled mine out last week to go through my engine and stuff and it's rotted pretty bad on the front side Quote Link to comment
Dguy210 Posted September 23, 2023 Report Share Posted September 23, 2023 BTW the 240SX radiator may work for you and is available from Vatozone for under a $100. Made for a KA24E so easily does a Z22. https://www.autozone.com/cooling-heating-and-climate-control/radiator/nissandatsun/240sx 1 Quote Link to comment
Connor Snyder Posted September 23, 2023 Report Share Posted September 23, 2023 14 hours ago, datzenmike said: Good price! The stock is double row? I can't remember but it is much larger (L&W) than the earlier Z22 but thinner. I know this is a little off the subject. But do you know if the bigger z24 rad will go in my z22 trucks? z22 rads are absolutely not avaliable anymore but I can get the z24 rad easy 1 Quote Link to comment
bottomwatcher Posted September 23, 2023 Report Share Posted September 23, 2023 11 hours ago, Dguy210 said: BTW the 240SX radiator may work for you and is available from Vatozone for under a $100. Made for a KA24E so easily does a Z22. https://www.autozone.com/cooling-heating-and-climate-control/radiator/nissandatsun/240sx Maybe. I have gone the other way with a 240sx intake KAE to a stock 720 radiator. The hose routing looks kind of Dr. Seuss ish. Funny how a radiater inlet or outlet only a couple of inches off can cause a coolant hose routing nightmare. I would stick with the stock one if keeping it stock. 1 Quote Link to comment
DwayneOxford Posted September 23, 2023 Report Share Posted September 23, 2023 I put one for cab chassis on my '85. Only minor hose differences. Also cobbled up drain in bottom hose. 1 Quote Link to comment
builte Posted September 24, 2023 Author Report Share Posted September 24, 2023 On 9/22/2023 at 8:13 PM, Dguy210 said: BTW the 240SX radiator may work for you and is available from Vatozone for under a $100. Made for a KA24E so easily does a Z22. https://www.autozone.com/cooling-heating-and-climate-control/radiator/nissandatsun/240sx I will give this a go thank you Quote Link to comment
