720 3VZE swap
Berkybot
The 3VZE is a 3.0 v6 made by Toyota in the 80s and 90s. The engine was pretty underwhelming at the time but I was wondering if it was possible to throw it in a 720 and if it would be better than a z24. I’ve heard they have respectable torque which would go well with the possible dually conversion im considering. Any ideas or advice let me know, thanks.
  • Replies 6
Oh, you mean the 3 point slow?
Not a great motor by any means, but yes, it would make more power than a Z24.
A better swap would be a KA24. It makes 150hp minumum, which is about the same as the Toyota V6. It's not a bolt in swap, but it would at least bolt to the trans and fit better overall. @]2eDeYe makes motor mounts for a KA swap.
I just had a thought. If you were building a crawler, then yes, the 3.0 would be better than a Nissan motor. SImply because of the transmission and transfer case options. You can bolt an R151F Turbo trans to it, which has a 4.3:1 first gear. From there, the RF1A t-case bolts up, with gear options as low as 5:1.
No Datsun/Nissan combo can even compare.
  • 2 months later...
