ney Posted September 19, 2023 Report Share Posted September 19, 2023 Hi, I have a 1971 datsun 521, that keeps flooring cylinder #3. it had a after market carburetor (cheap one $75) and ran good for a few years. I left it parked 6 months and now runs really rough. I replaced fuel filter, cleaned the carburetor and I noticed that cylinder #3 flooded, luckily I found an original one, I cleaned it really good and I had the same result. I checked the flood and it seams to be working properly, it only takes a few seconds to flood the same cylinder. Can two carburetors have the same problem? or there is something else wrong. I need some help 😞 😞 Quote Link to comment
datzenmike Posted September 19, 2023 Report Share Posted September 19, 2023 Maybe spark plug not firing? Gas just keeps collecting. 1 Quote Link to comment
Stoffregen Motorsports Posted September 19, 2023 Report Share Posted September 19, 2023 Are you sure it's not oil fouling? Quote Link to comment
banzai510(hainz) Posted September 22, 2023 Report Share Posted September 22, 2023 (edited) this what I would do. make sure cyl 3 has spark or a new plug there. make sure the rocker arms are set correct.Valve lash maybe a hole in the piston? Those it seem to run OK for a little bit like on all 4 before it floods/fouls out?If hole in piston plug with be soaked with oil. dos oil look or smell like gas? Edited September 22, 2023 by banzai510(hainz) 1 Quote Link to comment
