Heater Delete Coolant Hose Routing?
SupDoc
  • Replies 4
What ever you choose, coolant flow must be stopped just like when the heater control is OFF. Most of the year the above picture will work, but on extremely hot days that's hot water being routed right back into the engine by passing the radiator and that will stress the cooling system.
If you’re not running the heater and you have a hose going like the op picture put a 5/8” plug in that hose.
Like Mike pointed out if the hose isn’t plugged your pumping hot water into to motor inlet for water making things hotter in hot weather.
I cut a 5/8” bolt and stuck it in the hose at the head fitting. Added a clamp where the plug is to hold it in place.
