gh0stwerx76 Posted September 30, 2023 Report Share Posted September 30, 2023 On 8/13/2023 at 7:59 PM, 521miscreant said: Does that work well with Steel lines? I'm gonna redo the fuel lines too once I decide what I am doing for and engine. I'm thinking the fuel lines should be steel. yes, you can infinitely tune your bends to follow changes in the floor and rail shape. very pleasing final results from every experience. with steel line you can also use map gas to heat where you'd like a bend and go slow and gentle and you'll have satisfactory results. Quote Link to comment
521miscreant Posted 19 hours ago Author Report Share Posted 19 hours ago (edited) I'm still alive and working on this. I cleaned up this ugly patch. I'm guessing the accelerator pedal broker through or something. New to welding so it took me a while. Edited 19 hours ago by 521miscreant delete error mesage 2 Quote Link to comment
521miscreant Posted 19 hours ago Author Report Share Posted 19 hours ago So wanted to confirm...this is a dent and not the way it should be... I'm hoping to get he floor all cleaned up to I can put the cab back on the frame soon. Feel free to bash my welding job. Quote Link to comment
Stoffregen Motorsports Posted 8 hours ago Report Share Posted 8 hours ago Be sure to check the weld for pinholes. Use an LED flashlight on the back side and turn off the shop lights. Quote Link to comment
NC85ST Posted 4 hours ago Report Share Posted 4 hours ago That looks a hundred times better than it did. Your second picture looks like a dent, but I’m not 100% sure where that is on the truck. 1 Quote Link to comment
521miscreant Posted 4 hours ago Author Report Share Posted 4 hours ago 24 minutes ago, NC85ST said: That looks a hundred times better than it did. Your second picture looks like a dent, but I’m not 100% sure where that is on the truck. Its where the passenger side floorboard curves up into the transmission tunnel and up towards the firewall. Pic is taken from the bottom. The cab is upright resting on the back window side. I'm pretty sure it is a dent, but it is so clean and there wasn't any damage to the paint where it was at, so it has me second guessing. 4 hours ago, Stoffregen Motorsports said: Be sure to check the weld for pinholes. Use an LED flashlight on the back side and turn off the shop lights. Yup. I had a light underneath. I think I picked the most difficult part to repair since it has the curve going down on the right and also a bend in the middle from top to bottom. It's not perfect, but I didn't want to let perfect be the enemy of good enough. 1 Quote Link to comment
