Treycookies Posted July 26, 2023 Report Share Posted July 26, 2023 1985 z24 king cab Haven’t been able to get a spark passed my distributor despite it being extremely clean. I ran through the diagnostic tests listed in my repair manual and when testing the ICM ground (voltmeter from negative battery terminal to distributor housing metal and crank the engine) I got .25 volts. The manual suggests replacing the icm if it’s less than .5 volts. Is there a way to repair this or do I need to shell out for the 50 dollar part? Quote Link to comment
datzenmike Posted July 26, 2023 Report Share Posted July 26, 2023 The module is self contained circuitry, no way to tamper with it. If you performed all the tests in order then I guess get your Grant out. Quote Link to comment
Treycookies Posted July 27, 2023 Author Report Share Posted July 27, 2023 Thanks Mike Quote Link to comment
Treycookies Posted August 7, 2023 Author Report Share Posted August 7, 2023 Ok so I put in a new icm and… nothing. Same result on the ground test (.25v) and still no spark to the plugs. I am getting spark from the coils- they both test good and wires from the coil produce spark. But nothing coming out of the distributor has spark. Any ideas? Quote Link to comment
datzenmike Posted August 7, 2023 Report Share Posted August 7, 2023 Rather than the distributor check if the coils are firing. Quote Link to comment
Treycookies Posted August 7, 2023 Author Report Share Posted August 7, 2023 Sorry what do you mean by that? They both test good on primary and secondary circuits and produce a spark when cranked. Quote Link to comment
Crashtd420 Posted August 7, 2023 Report Share Posted August 7, 2023 2 hours ago, Treycookies said: Ok so I put in a new icm and… nothing. Same result on the ground test (.25v) and still no spark to the plugs. I am getting spark from the coils- they both test good and wires from the coil produce spark. But nothing coming out of the distributor has spark. Any ideas? Have you replaced the cap and rotor recently too? Is there any chance you have the wrong cap or rotor on the distributor? Not even sure if that's possible... Only other thing I think of is the timing is so far off its firing in between..... Have you messed with the distributor at all? Quote Link to comment
datzenmike Posted August 7, 2023 Report Share Posted August 7, 2023 2 hours ago, Treycookies said: Sorry what do you mean by that? They both test good on primary and secondary circuits and produce a spark when cranked. So when starting, the coils fire?????????? Well then the module is working then. Rotor is likely positioned between wires and can't get to the plugs. Set engine to TDC compression on number one cylinder. Take the cap off the distributor. The rotors should be pointing to the number one plug wires. 1 Quote Link to comment
Treycookies Posted August 7, 2023 Author Report Share Posted August 7, 2023 Ok I’ll give that a shot. Thanks guys. Quote Link to comment
banzai510(hainz) Posted August 7, 2023 Report Share Posted August 7, 2023 51 minutes ago, datzenmike said: Rotor is likely positioned between wires and can't get to the plugs im thinking this Quote Link to comment
