datsun_celaya620 Posted June 24, 2023 Report Share Posted June 24, 2023 Was replacing rear studs ln my 78 620 and this spring was snapped when I took off the drum brake I tried looking for it online but nothing comes up can I use any other drum brake kit and will it fit fine ? My grandpa told me it was the spring that brings the brakes back in after you step on the brake pedal if that helps sorry for no pic Idk how to use imgur Quote Link to comment
thisismatt Posted June 24, 2023 Report Share Posted June 24, 2023 SPRING-RETURN,REAR BRAKE UPPER 44070-32200 2 SPRING-RETURN,REAR BRAKE LOWER 44071-36700 2 Those are the part numbers, you might be able to find new or aftermarket 1 Quote Link to comment
mklotz70 Posted June 25, 2023 Report Share Posted June 25, 2023 I'm pretty sure they're 10" brakes......just like they have been since the 320........and into the HB/D21. If you can't find one specific to the 620, I'd grab a couple from an HB at the scrap yard. Rockauto should have repair kits with the springs. Quote Link to comment
banzai510(hainz) Posted June 28, 2023 Report Share Posted June 28, 2023 I believe Partsgeek had spring kits also Quote Link to comment
