411 Swaybar Link Bushes
Looking to replace my swaybar bushes on my 411. Mine are shot.
Anyone got any links to replacements? I recall reading something that 510 bushes may be the same. Can anyone shed any light on this?
Superpro list a range of bushes for the 510.
https://superpro.com.au/find/superpro-suspension-parts-and-poly-bushings-for-nissan-datsun-1600-1968-1972-p510-/cid-999500716
I'm in Australia.
Thanks in advance.
  • Replies 8
Yes they do but for most other suspension parts I find they are too stiff an non compliant. Rubber grips both moving parts and flexes internally, poly will chafe, squeak and wear. Rubber is far superior for vibration isolation.
Let me be more specific.  I used poly bushings on my sway bar. That is the subject of this posting after all.
  • 1 month later...
Troy,
When I replaced mine on my 411 sedan, about 8 years ago, I could not find end or center bushings that would work. So, I did the following:
-End bushings: Cast my own using castable urethane with a softener to get the hardness down to about 70A
-Center/locator bushings: The same. This was a tricky mold to make.
-Links: I found a generic link kit with bolts, spacers, washers and bushings by measuring the stock ones and scrolling through an aftermarket car parts website; they fit perfectly.
They were still holding up perfectly when I sold the car last year. The entire process took a few days and taught me urethane casting, which I've used many times since.
Jesse.
