rattyrat Posted June 24, 2023 Report Share Posted June 24, 2023 I have a pair of these ready to go on my 2 door. I have the spring clips and bolts too. There seems to only be a bolt hole on the front fender area both on the car and on the trim. There are no holes elsewhere on the trim pieces or on the car. Is it literally a case of just sticking them on with adhesive? What purpose do the spring clips provide? Quote Link to comment
datzenmike Posted June 24, 2023 Report Share Posted June 24, 2023 The Feb '72 and on molding has the two threaded fasteners and needs two holes. If you have an earlier sedan it probably won't work. Rather than drilling holes in the body just use automotive two sided tape. 1 Quote Link to comment
rosso Posted June 24, 2023 Report Share Posted June 24, 2023 Both old and new style moldings use the clips and bolts as in the diagram below. If your car does not have 4 or so holes for the spring clips, maybe someone filled them in. Quote Link to comment
datzenmike Posted June 24, 2023 Report Share Posted June 24, 2023 Bugger me. I forgot to check the qty of clips. Yes 4 per side so four holes. Quote Link to comment
thisismatt Posted June 24, 2023 Report Share Posted June 24, 2023 (edited) 6 total mount points. Edited June 24, 2023 by thisismatt 1 Quote Link to comment
datzenmike Posted June 24, 2023 Report Share Posted June 24, 2023 My parts call out are for 8 clips. Quote Link to comment
thisismatt Posted June 24, 2023 Report Share Posted June 24, 2023 1 hour ago, datzenmike said: My parts call out are for 8 clips. Yeah, 6 mount points per side. 4 clips, 2 bolts, per side. Quote Link to comment
datzenmike Posted June 24, 2023 Report Share Posted June 24, 2023 Ahhh now it's clear. Quote Link to comment
rattyrat Posted June 24, 2023 Author Report Share Posted June 24, 2023 shoot...they must be filled in then because the only holes are on the front fenders..i guess i'll leave the trims for now, kinda like the clean look anyway Quote Link to comment
