Ce953 L series cam identification
G'day, I bought a reground L series cam a while ago, supposedly a mild rally cam that was ran with su carbs back in the day. Its called a ce953, and I haven't been able to find any evidence of it even existing on the internet. Does anyone know anything about it? Manufacturer? Specs? Thanks in advance. Wilson
  • Replies 4
Is there any other information scribed on the back end of the cam? Often the duration is marked but not always.
You should be able to figure out the lift by measuring the width across the highest point on the lobe and subtract the base circle off the lobe and multiply by 1.5 for the valve lift. For example the L20B lift is 0.413"
Interesting. Thanks. The seller gave me some specs from his memory, and he said its meant to be 8.6mm lift or so, and 274 degrees duration. Not much lift compared to other mild cams, and I was wondering if its measured at the cam lobe, whereas others may be measured at the valve? It probably just doesn't have much lift. The base circle doesn't look like its been cut much, but some has been taken off the top of the lobes definitely. Was probably on an L18 or smaller.
