rattyrat Posted June 6, 2023 Report Share Posted June 6, 2023 I can't see any leaks in or around the car but the interior stinks of gas and it's making me feel lightheaded...lifted the carpets and i'm not 100% sure what's going on here but does this setup look correct? I assume this is the wiring for the fuel pump running along the floor and then squashed under the rear seat (I hope it's not actually a fuel line lol) - and then I have two plugs just laying on the trunk floor near the fuel tank.. Battery etc are completely disconnected as i'm scared of any kind of spark with the stench of gas. I can take more photos if it helps Quote Link to comment
datzenmike Posted June 6, 2023 Report Share Posted June 6, 2023 This is the gas gauge sender and tail lights wiring, I hope??? Check the filler hose to the tank and next see if you have a gas tank vent line (aluminum I think) that goes to the flow guide valve on the left strut tower. European 510? may not have this but the tank may have the outlet pipe (sealed) and the seal may have come off letting fumes out into the boot. (trunk) Is there anything above the gas tank? We got multiple ways to collect fumes from the tank to keep them escaping into the environment. Is there anything above the tank? 1 Quote Link to comment
thisismatt Posted June 6, 2023 Report Share Posted June 6, 2023 Not a single photo of the fuel filler or lines 😅 1 1 Quote Link to comment
rattyrat Posted June 6, 2023 Author Report Share Posted June 6, 2023 5 minutes ago, thisismatt said: Not a single photo of the fuel filler or lines 😅 i'm gonna take pics now LOL Quote Link to comment
rattyrat Posted June 6, 2023 Author Report Share Posted June 6, 2023 here's the pics, also i can't get underneath to take fuel line pics at the moment, my back is hurting a lot @datzenmike @thisismatt should the pipe that goes through the floor be connected to the opening on the top left that has nothing over it? Quote Link to comment
KELMO Posted June 6, 2023 Report Share Posted June 6, 2023 1 hour ago, datzenmike said: Check the filler hose to the tank and next see if you have a gas tank vent line (aluminum I think) that goes to the flow guide valve on the left strut tower. I think DM is talking about the 3 way valve, in the engine compartment, on the left strut tower. If so, I do not see anyting other than what looks to be windshield washer line coming out of the floor and laying in the spare tire wheel well. Have you removed the fuel sending unit recently? And, if so, did you replace the o-ring for it with a new one or reuse the old one? FWIW, both of my 1200's smell like gas, I just roll down the windows.😆 1 Quote Link to comment
datzenmike Posted June 6, 2023 Report Share Posted June 6, 2023 Europe may not have the same emissions package for collecting and storing gas tank fumes. 1 Quote Link to comment
rattyrat Posted June 6, 2023 Author Report Share Posted June 6, 2023 41 minutes ago, datzenmike said: Europe may not have the same emissions package for collecting and storing gas tank fumes. sorry I should have explained the car is originally from Japan also @KELMO i have not removed anything yet, everything is as i bought it so not sure what work has been done Quote Link to comment
thisismatt Posted June 6, 2023 Report Share Posted June 6, 2023 Uhh, there's an open line right there 😅 Quote Link to comment
mojojojo78 Posted June 6, 2023 Report Share Posted June 6, 2023 7 minutes ago, thisismatt said: Uhh, there's an open line right there 😅 I saw this in the first picture. Is this what you are talking about? Quote Link to comment
datzenmike Posted June 6, 2023 Report Share Posted June 6, 2023 Yeah, what is this? probably vent or return if the JDM had this. Quote Link to comment
thisismatt Posted June 6, 2023 Report Share Posted June 6, 2023 1 minute ago, mojojojo78 said: I saw this in the first picture. Is this what you are talking about? Yup Quote Link to comment
rattyrat Posted June 6, 2023 Author Report Share Posted June 6, 2023 i've covered that open line up already with some tape and ordered some new pipe...i tried refitting the original but it's all crumbly and rotten! also ordered a new gasket for the gas cap as the one on there at present is completely perished which probably doesn't help with things.. thank you guys :) (this is the pipe that is supposed to go in that open line, it leads out through the trunk floor) Quote Link to comment
thisismatt Posted June 6, 2023 Report Share Posted June 6, 2023 That tank looks like a later EVAP tank, so you're missing the tank reservoir and associated plumbing. If you vent that one to atmosphere, make sure you run it up as high as you can before dropping it back down 1 Quote Link to comment
