badass620 Posted May 18, 2023 Report Share Posted May 18, 2023 Greetings. Anybody swap a full body of a 620 onto a newer chassis? Quote Link to comment
datzenmike Posted May 19, 2023 Report Share Posted May 19, 2023 The 620 will fit the 720 frame. Short wheelbase to short wheelbase. Long wheelbase (long box) to long wheelbase. KC to KC though you can swap a KC onto a long wheelbase (long bed) by cutting the L&R front bed mounts off. I put my '78 body onto an '82 720 long bed Quote Link to comment
badass620 Posted May 19, 2023 Author Report Share Posted May 19, 2023 Thank you. Quote Link to comment
Stoffregen Motorsports Posted May 19, 2023 Report Share Posted May 19, 2023 Guys here have done it. I can't think of any specific thread, so maybe try the search button. Quote Link to comment
EDM620 Posted May 29, 2023 Report Share Posted May 29, 2023 I'm doing a 620KC onto a 720 long. Only the front box mounts need to be relocated and a little nip off the frame tails, otherwise it all fits. One thing that is different and to be aware of is the location of the steering box - the 720 mounts to the other side of the frame rail, so a small fender massage is required. 1 Quote Link to comment
datzenmike Posted May 29, 2023 Report Share Posted May 29, 2023 Yeah mine was a '78 KC forgot to mention. I moved the two front bed mounts but as it was a flat bed it didn't really need this. Put the 620 steering column in to begin with then a 720 column with 280zx PS box, then D21 PS box on outside of frame when I went to Toyota 4x4 solid front end. 1 Quote Link to comment
EDM620 Posted June 2, 2023 Report Share Posted June 2, 2023 I assume the D21 frame is also pretty much spot-on for the 720 frame, so effectively there is that option as well. Quote Link to comment
datzenmike Posted June 2, 2023 Report Share Posted June 2, 2023 That I don't know. The 720 is a larger truck than the 620 and the D21 larger still. If the frame rails are the same distance appart then it might be the same cab and box mounts. Maybe... Quote Link to comment
