datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 That's better. Take the driveshaft off the differential and try turning it by hand while in neutral. Turns easily? turn the pinion flange. Transmission oil level checked??? Differential oil level checked??? Quote Link to comment
22350 Posted May 5, 2023 Author Report Share Posted May 5, 2023 (edited) 30 minutes ago, datzenmike said: That's better. Take the driveshaft off the differential and try turning it by hand while in neutral. Turns easily? turn the pinion flange. Transmission oil level checked??? Differential oil level checked??? Truck rolls with the truck in nutral Transmission rebuilt with 120w oil and checked when this happened Differential rebuilt with 3.7 gears I filled the differential myself 6 weeks ago Edited May 5, 2023 by 22350 Quote Link to comment
Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 FInd the smoking gun. Quote Link to comment
22350 Posted May 5, 2023 Author Report Share Posted May 5, 2023 4 hours ago, Stoffregen Motorsports said: FInd the smoking gun. We should have a pretty good idea, once we get the transmission out. At least it is happening at the same time as suspension 1 Quote Link to comment
datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 Aren't you going to find out if transmission or rear axle first?? Quote Link to comment
22350 Posted May 5, 2023 Author Report Share Posted May 5, 2023 (edited) 23 minutes ago, datzenmike said: Aren't you going to find out if transmission or rear axle first?? When you say "rear axle" ... the truck wouldn't roll when put in nutral, if the differential was broken, or am i missing something? Edited May 5, 2023 by 22350 1 Quote Link to comment
datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 Missed that part. Carry on. 2 Quote Link to comment
