Stoffregen Motorsports Posted June 20, 2023 Report Share Posted June 20, 2023 Found this too - https://www.wellingtonautomotive.co.nz/product-562b7501276330c2df25533f Quote Link to comment
datzenmike Posted June 20, 2023 Report Share Posted June 20, 2023 With so much talk about a 5 speed in your 521, you are aware that the 71B 5 speed does not just drop in? Your, I assume, stock 4 speed is 26" and the 5 speed 31.5" so driveshaft will need to be taken to a shop and shortened by 5.5". In addition the 521 transmission mount will need to be sectioned and welded. Quote Link to comment
datzenmike Posted June 20, 2023 Report Share Posted June 20, 2023 1 hour ago, Stoffregen Motorsports said: Turns out you can buy new close ratios gear sets - https://jdm-car-parts.com/products/kameari-performance-71b-5-speed-transmission-close-gear-set-for-skyline-hakosuka-kenmeri-laurel-fairlady-z-datsun-240z?variant=32238107459693 Yeah if you like the feel of taking off in second. 1 Quote Link to comment
robrizzo Posted June 20, 2023 Author Report Share Posted June 20, 2023 Omg. I have never taken apart a trans. Grrrr Quote Link to comment
datzenmike Posted June 20, 2023 Report Share Posted June 20, 2023 No need to take apart, you only have to fit the transmission into the truck as outlined. Quote Link to comment
robrizzo Posted June 20, 2023 Author Report Share Posted June 20, 2023 Getting drive shaft is easy easy easy. changing the mount also easy I took some photos and should have taken more. I use a mount from another hour because the price for a 521 mount was over 100 Quote Link to comment
Stoffregen Motorsports Posted June 20, 2023 Report Share Posted June 20, 2023 2 hours ago, datzenmike said: Yeah if you like the feel of taking off in second. Funny you mention that. We gave to push our MG Midget to get going. We can go through turn 11 at Sears Point in first. Super close gear ratio. 1 Quote Link to comment
gkw619 Posted July 3, 2023 Report Share Posted July 3, 2023 On 4/19/2023 at 6:20 AM, datzenmike said: The 521/620 720 and D21 Hardbody WD21 Pathfinder and probably Xterra all use the same 6 lug pattern. Toyota/Mazda/Isuzu 6 lug also fit as does GM and Ford. I sent you a private message with a calculator tool for comparing what you have now with what might work. There is no easy answer for this, you have to make some measurements and plug the numbers in. Generally stock rims are probably zero offset but this can be confirmed with a tape measure. Would you send me this calculator as well please? Quote Link to comment
mainer311 Posted July 4, 2023 Report Share Posted July 4, 2023 (edited) 19 hours ago, gkw619 said: Would you send me this calculator as well please? I always use: http://Www.willtheyfit.com Edited July 4, 2023 by mainer311 Quote Link to comment
