vitracker Posted April 13, 2023 Report Share Posted April 13, 2023 Hi, I came across this forum looking for information on my 720 motorhome I acquired the fall. I've since did some front end work, brakes, some minor fixes inside and out. I found the 720 FSM and it helped a lot. I have no been able to find anything on the "vanguard" camper and wondering if perhaps someone on here had one. It was constructed in BC. The only thing I couldn't get working was the horn and horn button. I just added a push button for now, just to have it working. Just wanted to say hello. It amazingly drives along pretty good. I can't think of any other early 80's carbureted 4 cylinders that could push thing along, but the Z24 seems up to the task. 4 Quote Link to comment
]2eDeYe Posted April 13, 2023 Report Share Posted April 13, 2023 Welcome, great looking motorhome 🙂 1 Quote Link to comment
datzenmike Posted April 13, 2023 Report Share Posted April 13, 2023 Put your location in your profile. I'm on the Island. The Z24 is a torque monster of an engine and was only used in trucks. They do tend to blow head gaskets every 100k so once a year when the engine is cold loosen one head bolt and tighten to 60 ft lbs. Only then move to the next bolt and loosen/tighten it. With only one bolt loose at a time you can do in any order you like. This will keep a uniform clamping pressure on the gasket. 1 Quote Link to comment
vitracker Posted April 14, 2023 Author Report Share Posted April 14, 2023 I'm on the "other" island... Newfoundland! This thing made the cross country journey at some point before I owned it. I kept front plate BC on since we only issue rear plates here 😉 Thanks for the tip on the head bolts. I will do that next time I'm under the hood. It has 157,000km, and everything looks original. Quote Link to comment
datzenmike Posted April 14, 2023 Report Share Posted April 14, 2023 That's 100k miles so 160,000km you're ready to blow. The other Z20 and Z22 didn't have this problem only the Z24. 1 Quote Link to comment
bottomwatcher Posted April 14, 2023 Report Share Posted April 14, 2023 My Z22 blew a headgasket just fine. Twice! I road tripped up the west coast of Newfoundland last summer. You live in a magnificent place! 1 Quote Link to comment
