MC012 Posted December 3, 2022 Report Share Posted December 3, 2022 I have a 1978 B210 GX and have had some electrical problems recently. I’m at a point where I have a new alternator and starter and now am having trouble keeping the car running. The car will turn over and start, but when it starts there is a loud grinding sound and goes away when you let off the ignition. If you stop before you hear that sound for a second it will not start. Once it is started however it will only stay running for a few seconds, very poorly too. I’m having trouble diagnosing and trouble shooting and can’t afford to go replacing things that have the slightest connection to the ignition system. I appreciate any help on where I should start looking and what to look for. Quote Link to comment
datzenmike Posted December 3, 2022 Report Share Posted December 3, 2022 Why was the starter replaced? Was the old one doing the same grinding noise???? Go out and take the top off the air filter and look. If engine is cold step on the gas. Does the choke flap close? Quote Link to comment
MC012 Posted December 3, 2022 Author Report Share Posted December 3, 2022 Starter was replaced due to misdiagnosis. Will check to see if the choke flap closes as soon as I can. I’m not entirely sure it’s the starter making the grinding noise Quote Link to comment
datzenmike Posted December 3, 2022 Report Share Posted December 3, 2022 Was the old one making that grinding noise? Or did it start with the new one??? Quote Link to comment
MC012 Posted December 3, 2022 Author Report Share Posted December 3, 2022 The reason I replaced it was because it wouldn’t start at all, but it ended up being a battery issue and not a starter issue, before then there was no grinding sounds or trouble running Quote Link to comment
datzenmike Posted December 3, 2022 Report Share Posted December 3, 2022 Old starter no grinding... New starter, grinding. Thus the change to the new starter is causing the grinding. Never throw original Nissan parts away. The replacement is always of inferior quality. Often known as bad in the box. a/ Put the old starter back on. If it was traded in... b/ Return it for another. Quote Link to comment
MC012 Posted December 5, 2022 Author Report Share Posted December 5, 2022 I still have the old starter and probably will throw it in but the grinding is less of the issue and more if a symptom of the issue. I’ve talked with some more experienced techs and they’ve mentioned it could be a wiring issue from the ignition so that the only signal being sent is to the starter causing it to disengage properly and the engine to not continue running. And the choke flap does close. Quote Link to comment
datzenmike Posted December 5, 2022 Report Share Posted December 5, 2022 Well did the original starter have problems? Put it in and try it. If it goes away then good and done, the new one is a spare. If you still have problems that are the weak signal from the ignition key then that can be fixed. Quote Link to comment
banzai510(hainz) Posted December 5, 2022 Report Share Posted December 5, 2022 does it run if you cycle the gas pedal after it starts???????? maybe the idle jet is plugged????? Quote Link to comment
afracer Posted December 19, 2022 Report Share Posted December 19, 2022 A worn ignition switch could be the cause of your starter issue; it's a cheap and easy replacement that probably needs replacing regardless. Otherwise I'd drop your transmission and ensure the flywheel isn't damaged and also ensure your engine plate is there between the engine and transmission. Quote Link to comment
datzenmike Posted December 19, 2022 Report Share Posted December 19, 2022 MC012 was last here 07 December. Quote Link to comment
