Stoffregen Motorsports Posted March 1, 2023 Report Share Posted March 1, 2023 Could be. Take a pic of the new one laying next to the old one on a work bench. That will tell us a lot. Quote Link to comment
banzai510(hainz) Posted March 1, 2023 Report Share Posted March 1, 2023 (edited) make sure your kit have the bright links. The taiwan chain dont have the brite links so I just get a old chain set it next to it and mark it with paint . I have seen the newer OSK chain sets and there are still made in Japan but not as good as they used to be. The Tsubaki ones are the best Edited March 1, 2023 by banzai510(hainz) 1 Quote Link to comment
datzenmike Posted March 1, 2023 Report Share Posted March 1, 2023 Or count em. 42 links for the L16/18 Quote Link to comment
Povi Posted April 28, 2023 Author Report Share Posted April 28, 2023 Managed to get everything back together, new chain kit, cleaned up and re-gasketed everything. It's running really nicely now. The old timing chain was about half a link longer. It's crazy how much it affected the running and tune of the car. I expected some but not this much - had to fully adjust timing and carb tuning to make it run healthy but now it feels sturdy and has more get up to it. Looking forward to hopefully a summer of noise-free driving 2 Quote Link to comment
datzenmike Posted April 28, 2023 Report Share Posted April 28, 2023 As the chain and teeth wear the cam events happen later in relation to engine crankshaft position. This benefits low speed but does not help mid range and higher speed performance. Nissan allowed for this by providing two extra positions on the cam sprocket to adjust out the slack. Each adjustment position is about 4 degrees. A tooth is 9 degrees so you can adjust this amount. You can visually check the amount of slack by looking at the cam sprocket timing mark and adjusting as needed. Putting the cam back in proper timing will be noticeable. Quote Link to comment
