72 CnC_WaGon Posted December 10, 2008 Report Share Posted December 10, 2008 hello you guys im having a few problems with my lights(low beams). when i oul the switch they dont turn on but then i move the high beams around and on turns on bright and another turns on dim. its on a 1972 510 wagon . thanks you guys Quote Link to comment
banzai510(hainz) Posted December 10, 2008 Report Share Posted December 10, 2008 GO TO THE STRUT TOWER NEAR THE FUSE BOX there will be 2 relay looking canisters. try looking at them and near the fuse box ck for corrosion. als near the light. datsun wiring is pretty good and most times its just corrosion Quote Link to comment
ggzilla Posted December 10, 2008 Report Share Posted December 10, 2008 do you mean that when you wiggle the turn/signal stalk, the headlights come on/off? If so, the switch under the steering wheel is loose. Quote Link to comment
72 CnC_WaGon Posted December 11, 2008 Author Report Share Posted December 11, 2008 yeah when i wiggle the switch they go on and off. and i will check the fuse box thanks you guys Quote Link to comment
banzai510(hainz) Posted December 11, 2008 Report Share Posted December 11, 2008 wiggle the connectors by the fuse box also. it helpsbreak up the corrossion Quote Link to comment
420n620 Posted December 11, 2008 Report Share Posted December 11, 2008 if you got a small sandblaster, you can give the connectors a 1-2 seconds blast to clean them up w/fine sand. if not, use fine sand paper or scuff pad... I did this to my 72 Gt-37 a couple years ago and havent had a problem since. Quote Link to comment
ggzilla Posted December 12, 2008 Report Share Posted December 12, 2008 yeah when i wiggle the switch they go on and offThe problem is in the switch, not the fuse box. Unbolt the column cover and make sure all looks right inside. Then tighten the t/s to the column. That usually fixes it. Quote Link to comment
banzai510(hainz) Posted December 12, 2008 Report Share Posted December 12, 2008 well Im cunfused on this one ? He said he has no LOWBEAMS so it would have nothing to do with the switch in the column. The column has the highbeam ground to trigger the relay on the back of the strut tower near the fuse box area. When this happens it route 2 sets of grounds to the headlights. Cause the Lamps are already wire to the battery via fuse box. Unless Im off here please inform me. I will assume this is the standard cheap replaceable lamps. Quote Link to comment
ggzilla Posted December 13, 2008 Report Share Posted December 13, 2008 The switch in the column can switch off the lowbeams (in normal operation it does not). This happened to me when the switch was loose. Anyways think about it: Wiggle switch, headlights go wonky. What would a fuse have to do with that??? Quote Link to comment
Llittle_Llama Posted December 13, 2008 Report Share Posted December 13, 2008 and he hasn't been back since. i assume it is fixed :D good work all! Quote Link to comment
