Bahrbarian Posted August 23, 2022 Report Share Posted August 23, 2022 Hello All, I'm a new guy on the forum, but I was a Nissan/Datsun mechanic years ago and I'm on my second 620 because stupid me sold a rust free North Carolina '75 and kicked myself for letting it go ever since. Anyway, the reason for this thread is that I have pretty localized rust on my '73's cab mounts and I'm having a friend with a water jet work with me to make some new cab mount brackets that will overlay (or underlay, depending on how you look at it) the original reinforcement plates that are integral to the floor pan. I my case, my floors are good, except for where the body mount bolts mount the cab to the frame. The frame is solid but the reinforcement plate that is welded to the floor pan is basically gone where the rubber mount is, but the rest of it is still solid to the floor pan. I would prefer not to replace the whole floor pan, and I'm hoping that making this custom bracket will be cheaper and easier. I'm prototyping one now, and if they work well, I'd offer them on the forum if it would help other members as well. Sorry for the lack of pictures of what I'm actually trying to accomplish, but I guess I'm just wondering if this is a common situation, or if my situation is more unique and it's only going to be the right fix for my individual truck. I'm also wondering if someone else already is doing any kind of rust repair panels like this? In any case, I welcome any questions or feedback. Thanks, John 3 Quote Link to comment
Moist Lightning Posted August 26, 2022 Report Share Posted August 26, 2022 I think we talked briefly on facebook. I posted a 3d prototype of these. Hant had time to work on them for a while now. If you make some I would probably buy a set. My plan was to try and make a press to reproduce them from sheet metal but its a pretty thick piece with some dramatic bends so I'm not sure how well it would work out. Plan b is to make carbon fiber version but i doubt it would be worth my time to produce a lot of them in carbon fiber. If I can press them out of sheet metal would be easy to produce for others. As i said it will be a while before I get to this so if you beat me to it Ill probably just buy some if your are selling. Quote Link to comment
Bahrbarian Posted August 30, 2022 Author Report Share Posted August 30, 2022 It must have been someone else you spoke with on Facebook, but I'm glad there's talk about doing something like this for rust repair. It's taking me forever to work on this but I did weld up my prototype, and now I need to see how much metal I need to cut away to make them fit. These will be a thicker steel that will need to be welded to the original body reinforcement. I'm hoping to fit one in during this long weekend so I can have my first "real" set made up to install. I'll be taking pictures of the process and when I figure out how to post pictures here, I'll do it. Thanks for your interest! 1 Quote Link to comment
Stoffregen Motorsports Posted August 30, 2022 Report Share Posted August 30, 2022 How thick? Anything over 10ga is probably overkill. Quote Link to comment
