AbRamGom Posted August 6, 2022 Report Share Posted August 6, 2022 Was looking to do a disk brake conversion on the 520 but i want to keep the stock 6 lug wheel pattern but cant seem to find rims for them. Any recommendations on rims that may fit the stock lug pattern? If so what would they be and what modification would I have to do to make them fit? Quote Link to comment
wayno Posted August 6, 2022 Report Share Posted August 6, 2022 1978/79 Datsun 620 disc brake rims. Quote Link to comment
Stoffregen Motorsports Posted August 6, 2022 Report Share Posted August 6, 2022 13 hours ago, AbRamGom said: Was looking to do a disk brake conversion on the 520 but i want to keep the stock 6 lug wheel pattern but cant seem to find rims for them. Any recommendations on rims that may fit the stock lug pattern? If so what would they be and what modification would I have to do to make them fit? Guess it depends on what look you're after. If you want a stock look, stock 520 wheels will fit the disc brake setups of later trucks. I had stock 320 wheels on my 320 after I did the 720 balljoint coversion. No problems. If you want a stock look, but a little wider and larger diameter, stock steel wheels from a solid axle Toyota 4x4 (79-85 pickup/4runner) look great. Wheel Vintiques also makes a smoothie that looks like a stock steel wheel, but will take one of their cool hubcaps. 1 Quote Link to comment
datzenmike Posted August 7, 2022 Report Share Posted August 7, 2022 On 8/6/2022 at 12:42 AM, wayno said: 1978/79 Datsun 620 disc brake rims. 720 are also 6 bolt in 5, 5.5 and 6" X 14 and 5.5 and 6" X 15. The 720 also had an aluminum alloy rim option. 1 Quote Link to comment
1slowek9 Posted September 11, 2022 Report Share Posted September 11, 2022 Newer Toyota 4 runner wheels fit and look good IMO , that's what I'm running with my wilwoods 1 Quote Link to comment
