Stinky Posted July 21, 2022 Report Share Posted July 21, 2022 I was at a local junkyard...I bought a windshield and the PS pump set-up. They had 5 PUs and I popped all the hoods. They had one that looked like it was driven there...better shape than mine. Anyways....one of the 720s had a big radiator in it. It had a plastic tank...a big tank. I looked down through the fill hole and the tubes were at least 1" long. I think mine are about 1/2" Do the 4x4s have a different radiator? Quote Link to comment
datzenmike Posted July 21, 2022 Report Share Posted July 21, 2022 They do have a different radiator but likely same dimensions as 2wd to save production costs. The difference may be wider internal tubes for shedding heat. I had an L20B rad with three rows of tubes. Much smaller at under 1.2" each. Quote Link to comment
Stinky Posted July 21, 2022 Author Report Share Posted July 21, 2022 The PU that was nicer than mine had bucket seats swapped in with a console in the center. Quote Link to comment
720_Jeff Posted July 21, 2022 Report Share Posted July 21, 2022 If the tanks were plastic, pretty sure it is something a previous owner did. Originals should be painted copper. Quote Link to comment
Stinky Posted July 22, 2022 Author Report Share Posted July 22, 2022 The plastic crossed my mind. Quote Link to comment
Thomas Perkins Posted July 22, 2022 Report Share Posted July 22, 2022 (edited) I have a 85 4x4 with over 380,000 miles.It had the original one in it in 94 with 108,000 miles when I bought it for 3500,I have done put 3 in it from Autozone,they are plastic but has a lifetime warranty,as long as they have them,I never will have to buy them,same as the water pump.The last one lasted 11 years,when they go bad,I take the water pump out and get a free new one.The last radiator got a pin hole leak at the top.I also replaced my wife's 2004 lincoln LS radiator.It is plastic also,now that was a job doing that one.They don't have radiator caps on those.Got that one from Autozone too with lifetime warranty...They are 212.00 at Orielly's..with lifetime warranty,Autozone's are now way higher.Here is mine.. Edited July 22, 2022 by Thomas Perkins Quote Link to comment
