butter fingers Posted June 15, 2022 Report Share Posted June 15, 2022 the part # is SPAC0120 made by 4x4 parts.com . sorry i could not supply a link . they say more travel and a 3"lift . what do you experts think ? Thanks, Butter Fingers Quote Link to comment
720_Jeff Posted June 15, 2022 Report Share Posted June 15, 2022 This one: https://www.4x4parts.com/i-18915109-720-upper-control-arms.html Quote Link to comment
datzenmike Posted June 15, 2022 Report Share Posted June 15, 2022 Won't add 3" but will allow you to turn the torsion bars for 3 added inches. Hopefully without horrendous camber issues. Quote Link to comment
butter fingers Posted June 16, 2022 Author Report Share Posted June 16, 2022 hello , has any one tried an after market upper control arm ? Headers on my 720 don't excite me , but an upgrade on the front end does . I don't need 3 " of lift but 2 " would be great if my camber didn't go crazy out of wack ! B F Quote Link to comment
bottomwatcher Posted June 16, 2022 Report Share Posted June 16, 2022 Been running these since about 1991 when they came from Jim Conners racing. Crank them to three inch and it will ride like shit. 2 inches and an add a leaf in the rear levels the truck. The static camber can be set with a bunch of shims but don't make height changes afterwords because your camber will be wonky. Also don't install these and cheap out with reusing ball joints and other front end parts. There aren't many other options for suspension on these trucks. They did make ball joint spacers at one time I wouldn't combine them. I have 31s combined with a 2 inch body lift. Still needed fender trimming to prevent rubbing. 1 Quote Link to comment
butter fingers Posted June 16, 2022 Author Report Share Posted June 16, 2022 Thank you Bottomwatcher ! i plan on staying with my tires (235/75/15) because i like the height of the truck, no loss of power and the gearing is good too. i hope all the dads have a happy fathers day ! ! Butter Fingers 1 Quote Link to comment
