Norfair. Posted May 5, 2022 Report Share Posted May 5, 2022 Picking up a KA24E for my 620 Includes Motor Tranny Harness ECU For $750 Good deal or no? Quote Link to comment
]2eDeYe Posted May 5, 2022 Report Share Posted May 5, 2022 240sx or D21 set? Not that it matters, it's a good deal. 🙂 2 1 Quote Link to comment
Norfair. Posted May 5, 2022 Author Report Share Posted May 5, 2022 Guy pulled it out of his 240sx, heading sr20 way Will there be the same oil pan issue when mounting? Quote Link to comment
]2eDeYe Posted May 5, 2022 Report Share Posted May 5, 2022 You will have to flip the center link, or you can get a truck pan and sup for the single cam. You may have to drill the back dipstick hole if you do that though. 1 Quote Link to comment
Norfair. Posted May 5, 2022 Author Report Share Posted May 5, 2022 @]2eDeYei appreciate the info 🙏 I will pick it up this evening then! Quote Link to comment
datzenmike Posted May 5, 2022 Report Share Posted May 5, 2022 I guess you can't drive it to see if it's alright? Car KA oil pan won't work on truck. Can be made to work. Truck KA-e is a better fit but you'll have to modify yo clear the Car KA crankshaft girdle. Maybe combine them. Get the truck oil pickup tube. Try to get the EFI harness and ECU with it. I doubt if it's any use to a SR swap. You'll need it or have to find one. All the connections and sensors can be disconnected and the harness pulled through the firewall. Truck harnesses are different and are combined into the main harness. 1 Quote Link to comment
Stoffregen Motorsports Posted May 6, 2022 Report Share Posted May 6, 2022 We used to cut the girdle off for the race motors. So we could fit a dry sump oil pan. $750 is a smokin' deal. Is the motor complete with the intake tube and accessory drive? 1 Quote Link to comment
datzenmike Posted May 6, 2022 Report Share Posted May 6, 2022 Here's the engine girdle. A truck KA oil pan won't fit over it. Too bad 1 Quote Link to comment
Norfair. Posted May 8, 2022 Author Report Share Posted May 8, 2022 Sorry guys been a little busy but will be uploading pics soon! I appreciate everyones guidance on the matter 🤙🤙 1 Quote Link to comment
