Hitachi HJL38W Seal kit
Labubre
  • Replies 14
Mike you rule!!!
You know it
Already contacted
Another challenge?
Need also PCV hose that S/N is 11828-22001
Found it on NissanPart.Online.com
Just to be sure there is no other place i could find it...
image.pngX SSS SU PCV Hose 510 610 710 910 521 620 L16 L18 L20B 11828-22001 -  VINTAGE DATSUN AND NISSAN PARTS This is the SSS hose but out of stock.
Block vent hose to PCV valve.... and here my foo fails me. This pipe is on all  L series but the L16/18 are the same. The problem is the SSS engines use a different intake so the PCV is differently located and the pipe's pre formed shape is different.
N American L16/18 pipes are 11828-23002 or 11828-U6001 The L20B engine vent pipe is differently placed than the L16/18 because of the exhaust manifold used and is longer or certainly less curled? The part number is 11828-N5800 or U6702. Maybe you can find one of these pipe's pictures and compare to yours?
L16/18 hose
L20B hose
Datsun 620 Hose , Engine Crankcase Vent Hose L20B | eBay
I did have an L20B come to me with a piece of garden hose connecting the PCV valve end to the block vent hose end. You may have to make something work for now. Welcome to vintage car ownership.
  • 11 months later...
found on aussie forum nissan reference 16061-K1407
also reported to be same ref for roadster 2000 as found on 311s.org
ztherapy also sells the same part code for regular 510, 510sss and 2000 roadster (hjl-38W)
so i feel like this is a good one
available on nissanpartsdeal.com and amayama.com (i do not know this site)
4 hours ago, Labubre said:
Anybody know where to source floaters for this carb? Or interchange part?
Did not find the PCV hose yet as finally there was a mistake on nissanpart.online site.
Thx
Seb
My neighbor just bought a set from the local Nissan dealership  about 3 months ago.
Wa state but should be able to get anywhere .
Edited by bananahamuck
You can make a pcv hose for the SSS manifold using the 240z hose, cut it in the middle and shorten to fit and use an adapter to hold the two pieces together. I’ve made a couple this way and they work perfectly.
