Stoffregen Motorsports Posted September 1, 2023 Report Share Posted September 1, 2023 Aim to please. Quote Link to comment
EDM620 Posted September 2, 2023 Report Share Posted September 2, 2023 On 8/31/2023 at 10:18 AM, datzenmike said: Timming? That's what friends go do in Canada when it's too snowy to do much else... Are you addicted to the purple kool aid, I mean Tims?? 1 Quote Link to comment
datzenmike Posted September 2, 2023 Report Share Posted September 2, 2023 If traveling far enough I would. Only because there is no regulation against bad coffee ant gas stations. They are terrible. Tims, like McDees is consistent. The one you drink in Thunder Bay Ontario is the same as Squamish BC. No buyer's remorse. We have 2 or 3 in town but I have no reason to go there. I make the best of cheap drip coffee in my coffee press. I would make like a Biden voter and rise up from the dead and walk out of a Starbucks 1 Quote Link to comment
builte Posted September 25, 2023 Report Share Posted September 25, 2023 On 8/31/2023 at 9:10 AM, datzenmike said: Engine running? Set up the timing gun per the instructions. The timing mark is a notch on the pulley and should show in the flash of light as it passes the timing scale here. Might help to find it and mark with crayon or dab of paint... The very top point is ZERO degrees with 5 degrees between each peak and valley. Ignition timing is 3 degrees +- 2 degrees. To adjust there is a 10mm bolt on the distributor that is loosened and the distributor turned clockwise to increase the timing and counterclockwise to retard it. If adjusted you should check your idle speed it may go up if you advance and down if you retard the timing. You should put your location in your profile saves asking if California or not. I got the timing done on the first try 😁 I've got all the vacuum lines plugged off and have no idea if I hooked those three up correctly and it started right up and idled so smooth I appreciate you and stoffregen for the help on this subject. 1 Quote Link to comment
Datsun pickup Posted September 30, 2023 Author Report Share Posted September 30, 2023 If the engine is at tdc and the notch on the pulley is at +-3, do I need to adjust the timing with the engine running? Quote Link to comment
datzenmike Posted September 30, 2023 Report Share Posted September 30, 2023 TDC is at 0 or ZERO degrees. If reading anything is isn't. You might get the timing close on a non running engine but running and using a timing light is best. Quote Link to comment
Datsun pickup Posted October 4, 2023 Author Report Share Posted October 4, 2023 The engine will not stay running, only with the accelerator pedal. one coil is not getting any power, but the other one gets power until the rpm’s go down, then the volts drop, therefore it runs poorly. it also backfires a lot. Quote Link to comment
EDM620 Posted October 15, 2023 Report Share Posted October 15, 2023 Just thinking, the Z motor has dual coils and 1 fires on the exhaust side, the other on the intake side - the timing needs to align with the intake side - confirm your rotor aligns with the #1 INTAKE plug at TDC. The exhaust coil fires slightly after the intake coil. Quote Link to comment
datzenmike Posted October 15, 2023 Report Share Posted October 15, 2023 Both coils fire together at the same exact time. Set the timing light on any #1 plug. I think this problem has already been fixed. Quote Link to comment
