Thomas Perkins Posted February 5, 2022 Report Share Posted February 5, 2022 (edited) Okay Ya'll.Check your Calendars. Tomorrow is check your transmission fluid Day.I just got under mine and see no leaks,the teflon tape is doing good on the drain and fill plug.But I want to make sure.It is shifting good.I surely believe in preventive maintenance and I will look around under there to see if anything is out of place.My oil pan plug is not leaking.I use Red Line 4 MT-90 75W90 GL Gear Oil.I paid 37.20 for 2 quarts and had a little left over from Ebay back in August 2021 when I changed it.I had Red line in it when I changed it.It was dirty looking when I changed it and it only had about 8000 miles on it.So I will change it again in August.It shifts way better with this Redline.Here is a awesome pump I use that I got from Harbor Freight for 10 bucks.The end part that goes into the fluid container hole is bigger than the container hole so I use a Mobile 1 oil container cause it is much bigger than the other regular oil containers. And it fits good.The end piece fits perfect in the fill hole.It will be 54 degrees here in Georgia...After you use this pump,you will want to go slap your brother...2 pushes of the pump and your done with one quart. Edited February 5, 2022 by Thomas Perkins Quote Link to comment
datzenmike Posted February 5, 2022 Report Share Posted February 5, 2022 I'll do mine in June thank-you very much. 1 1 Quote Link to comment
Thomas Perkins Posted February 5, 2022 Author Report Share Posted February 5, 2022 June is go to Panama City Beach,Florida Month.... Quote Link to comment
datzenmike Posted February 6, 2022 Report Share Posted February 6, 2022 Up here it's warm 'n dry, good for climbing under car in gravel driveway month. 1 Quote Link to comment
Logical1 Posted February 6, 2022 Report Share Posted February 6, 2022 I also use MT-90 and it is awesome, being a synthetic it doesn't turn to molasses in the cold as much either! That big oil pump is manly and all but if you really want to work smarter not harder, these drill gun powered pumps with some cheap nylon tubing wins the prize. 2 Quote Link to comment
DwayneOxford Posted February 6, 2022 Report Share Posted February 6, 2022 But you're missing out on the exercise pumping manually. 1 1 Quote Link to comment
Thomas Perkins Posted February 6, 2022 Author Report Share Posted February 6, 2022 (edited) Nope Logical1,you came in a close second.Hi Dwayne.But any way,everyone has there way,but Mike has the coolest way.I just unscrewed the fill plug and it was still pink and perty clean, fluid started coming out so I have no leaks using this synthetic oil. ..I just drove to the new park here and took some pictures..It's almost a half mile from my house,they have 2 lakes,walking trails and other things.Also a BBQ restaurant across the street. Edited February 6, 2022 by Thomas Perkins Quote Link to comment
Veraciousreasoning Posted February 7, 2022 Report Share Posted February 7, 2022 That truck looks clean as fuck man good job. I can't wait to get mine looking like that. Quote Link to comment
