frankendat Posted June 21, 2023 Author Report Share Posted June 21, 2023 3 hours ago, Logical1 said: Upon closer measurement the stock hubs (which are the same size as the new hubs) are 98mm+/- Would you consider providing an opinion whether the wheels will clear the hubs? What is the diameter of the silver piece holding the manual lockout? Thank you Quote Link to comment
datzenmike Posted June 21, 2023 Report Share Posted June 21, 2023 4x4 wheel bearing preload is set without driveshaft installed. Tighten 58-72 ft lbs. Loosen Turn wheel both directions several times. Measure starting torque (A) on lug with a fish scale. Turn lock nut 15-30 degrees in tightening direction. Turn wheel both directions several times. Measure starting torque (B) on lug with a fish scale. Preload C is B - A and should be 1.59-472 pounds. Repeat till C is obtained. Install driveshaft. 2 Quote Link to comment
