Stinky Posted November 29, 2021 Report Share Posted November 29, 2021 On my 86 720, standard cab. The window started being difficult...had to crank, window would just drop unexpectedly. I finally took it apart. The shaft that the door handle goes on, on the back side, it is wallowed out. Which allows the shaft to wander around. I have a parts truck, but I havent seen this part yet. Does anybody know of a source for this part? I was looking at rockauto. They don't have it. But, I stumbled on to seat covers $140-190 sized to fit our 720s. I ordered one. Ill let you know. Quote Link to comment
MikeRL411 Posted November 29, 2021 Report Share Posted November 29, 2021 Is the handel recess boogered or the square portion of the shaft ? Unclear from yyour post. Quote Link to comment
NC85ST Posted November 29, 2021 Report Share Posted November 29, 2021 Probably easiest if you could post a picture of it. Quote Link to comment
Stinky Posted November 30, 2021 Author Report Share Posted November 30, 2021 I am looking for the register. The part that is wallowed out, is on the inside of the register. I holds the end of the shaft, on the inside. It is part the the sheet metal housing for the register. Quote Link to comment
Tucson620 Posted November 30, 2021 Report Share Posted November 30, 2021 Just went through similar issue on 521 - balky, so hard to crank finally broke handle. Window regulators are unobtainable for 521 trucks - maybe you can source replacements? Removed from door, cleaned ancient grease, etc. found 75% of resistance was just turning the crank bearing all by itself - no gears, arms, etc. Was due to wallowed out hole like this. Below is back side of sheet metal. My solution was to dremel down the sheet metal housing where wallowed out - basically just a steel bushing. I tack welded a washer as new material. Great improvement on both sides! Quote Link to comment
Tucson620 Posted November 30, 2021 Report Share Posted November 30, 2021 Always funny - looked up 720 window regulators on ebay (way more available than 521). And the design for 720 is damn near unchanged - same sheet metal bearing with wallowed out hole. Pic from ebay ad Quote Link to comment
Stinky Posted November 30, 2021 Author Report Share Posted November 30, 2021 (edited) Yep, dat is exactly what mine look like, just differnt ; ) I'll pull the one for my parts PU in just a bit. One of my problems, is that because the hole is wallowed, the gears didn't keep a tight clearance, and are sorta mangled. THey might work, might not. My first choice is gonna be my parts PU. The 2nd, will be Ebay, which you pointed out. I just looked, I did not find anything on Amazon. SOB, they are proud of them. You can get a new one, from Thailand & Australia for around 70 bucks. Or a used one, in the US, for over $100 Edited November 30, 2021 by Stinky Quote Link to comment
Stinky Posted December 6, 2021 Author Report Share Posted December 6, 2021 Welllllll, I ground the mushroom head off the shaft and ground it to a uniform diameter. Then I took a piece of bedframe angle (hard) and ground it down, almost round and drilled a hole in it. I started drilling it bigger until it would just fit on the shaft. I welded it on and then put it back together. After a week, my window has yet to drop on its own....what a change. It also rolls up and down easily. Sometimes, I'll grab it and it will surprise me how easy it cranks. Let's just say, that it is more than a little bit different now. Quote Link to comment
