weldingrod Posted September 7, 2021 Report Share Posted September 7, 2021 Looks like the two wheel drive has the removable front end and they used the dual wheel axle in the 4x4s. At least the one in the three 4x4's I have here have a diffy that looks like that one. Price of rear shoes in '98 was $6. Found this box in my storage. 1 Quote Link to comment
datzenmike Posted September 8, 2021 Report Share Posted September 8, 2021 All 2wd and 4x4s to and including '82 were H-190. All 4x4 from '83 on were C-200. I'm not sure what differential the Dual rear wheel axle was. May have been a C-200, maybe something else. 1 Quote Link to comment
weldingrod Posted September 8, 2021 Author Report Share Posted September 8, 2021 here's a question for you- I am swapping the axles and backing plates from the pooched diffy to the good one because the good one's backing plates are a mess and I don't want to go to all the trouble of pulling bearings, etc. Do I use the shims that are on the axles, or do I use the shims that come with the good diffy. They are all located at the same position. 1 Quote Link to comment
weldingrod Posted September 8, 2021 Author Report Share Posted September 8, 2021 As you can see, when I am finished with a vehicle there isn't much left for the scrapper. 1 Quote Link to comment
thisismatt Posted September 8, 2021 Report Share Posted September 8, 2021 I imagine the correct answer is to measure the axial play and shim accordingly. The axle tubes probably vary slightly in length, and possibly the axles themselves. 1 Quote Link to comment
datzenmike Posted September 8, 2021 Report Share Posted September 8, 2021 If doing both axles, set/check one to 0.011 to 0.035 inches. Set the other to 0.01 to 0.006 inches. The second shim setting removes all the internal play in the thrust block noticed when setting the first axle. If you were doing just one axle then the other side would already have the 0.011" to 0.035" set. 1 Quote Link to comment
